STM32 SPI通讯DA转换问题
4915|3
 楼主| firefox617 发表于 2012-3-13 23:37 | 显示全部楼层 |阅读模式
大家好!
     我用STM32和AD5660通讯做DA转换输出锯齿波,出现附图的波形问题,麻烦帮忙看看,谢谢!AD5660是24位数据输出。
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define SPI_FLAG_RXNE           SPI_I2S_FLAG_RXNE
#define SPI_FLAG_TXE            SPI_I2S_FLAG_TXE
#define SPI_FLAG_OVR            SPI_I2S_FLAG_OVR
#define SPI_FLAG_BSY            SPI_I2S_FLAG_BSY
#define SPI_GetFlagStatus       SPI_I2S_GetFlagStatus
#define SPI_SendData            SPI_I2S_SendData
#define SPI_ReceiveData         SPI_I2S_ReceiveData
/* Private variables ---------------------------------------------------------*/
SPI_InitTypeDef  SPI_InitStructure;
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Delay(vu32 nCount);
void SPI_SendByte(u8 byte);
void SPI2_Init(void);
u8 SPI_Send_Byte(u8 dat);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  vu16 Test1=0;
  vu16 Test2=0;
  RCC_Configuration();   //系统时钟配置函数
  NVIC_Configuration();  //NVIC配置函数
  //使能APB2总线外设时钟
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable, ENABLE);  //关闭调试 端口重新映射
  SPI2_Init();
   while (1)
//GPIO_Write(GPIOB, ~Test1); //写一个字数据到PB口
GPIO_SetBits(GPIOB, GPIO_Pin_12);
Delay(0x000F);
GPIO_ResetBits(GPIOB, GPIO_Pin_12);
SPI_Send_Byte(0x00);
//SPI_Send_Byte(0x00);
    SPI_Send_Byte(Test1>>8); //发送数据到SPI缓存
SPI_Send_Byte(Test1&0x00ff);
Delay(0x000F);
if(Test1==0x9fff)
Test1=0;
Test1++;
    //GPIO_SetBits(GPIOB, GPIO_Pin_12);   //片选
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  /* Configure SPI2 pins: NSS, SCK, MISO and MOSI */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
    /*Configure PA.4(NSS)--------------------------------------------*/
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  //GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14;
  //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  //GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* SPI1 configuration */
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;  //主机模式
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //8位数据
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;//SPI_CPOL_High=模式3,时钟空闲为高 //SPI_CPOL_Low=模式0,时钟空闲为低
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;//SPI_CPHA_2Edge;//SPI_CPHA_1Edge, SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;//SPI_NSS_Soft;//SPI_NSS_Hard
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;//SPI_BaudRatePrescaler_2=18M;//SPI_BaudRatePrescaler_4=9MHz
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;//数据从高位开始发送
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI2, &SPI_InitStructure);
    /*Enable SPI1.NSS as a GPIO*/
  SPI_SSOutputCmd(SPI2, ENABLE);
  /* Enable SPI2  */
  SPI_Cmd(SPI2, ENABLE);
* Function Name  : SPI_FLASH_SendByte
* Description    : Sends a byte through the SPI interface and return the byte
*                  received from the SPI bus.
* Input          : byte : byte to send.
* Output         : None
* Return         : The value of the received byte.
  /* Loop while DR register in not emplty */
  while(SPI_GetFlagStatus(SPI2, SPI_FLAG_TXE) == RESET);
  /* Send byte through the SPI2 peripheral */
  SPI_SendData(SPI2, dat);
  /* Wait to receive a byte */
  while(SPI_GetFlagStatus(SPI2, SPI_FLAG_RXNE) == RESET);
  /* Return the byte read from the SPI bus */
  return SPI_ReceiveData(SPI2);
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
* Function Name  : Delay
* Description    : Inserts a delay time.
* Input          : nCount: specifies the delay time length.
* Output         : None
* Return         : None
  for(; nCount != 0; nCount--);
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
 楼主| firefox617 发表于 2012-3-14 08:02 | 显示全部楼层
顶一下,大侠看看!
xwj 发表于 2012-3-14 08:52 | 显示全部楼层
先检查下布线看看
香水城 发表于 2012-3-14 14:38 | 显示全部楼层
一些建议:
1)没有人有耐心看大段的程序代码,请说明你是如何操作的。
2)输出波形与硬件密切相关,出问题不一定就是程序的问题。所以要把硬件环境描述清楚。
3)不少问题与具体操作步骤有关,因此你还需要描述操作步骤和测量方法。
