GD32F330CBT6 TIMER输出比较中断的问题
3950|2
 楼主| ecm1984 发表于 2021-9-2 10:34 | 显示全部楼层 |阅读模式
使用 TIMER0_CH0  比较输出, DMA 通道是CH1  CH3 还是CH4 ? 我现在3个都允许了
按第三步 设置了 通过 CHxIE/CHxDEN 位配置中断 /DMA 请求使能, 并没有请求DMA; 如果设置成 timer_dma_enable(TIMER0, TIMER_DMA_CH0D); 有DMA请求,但是我需要的是 每次比较完成请求DMA。
#include "gd32f3x0.h"
#include <stdio.h>
#define TIMER0_CH0CC  (TIMER0+0x34)
#define TIMER0_CH1CC  (TIMER0+0x38)
#define TIMER0_CH2CC  (TIMER0+0x3C)
#define TIMER0_CH3CC  (TIMER0+0x40)
uint16_t buffer0[4]={120,220, 620,650};
void gpio_config(void);
void timer_config(void);
void dma_config(void);
    \brief      configure the GPIO ports
    \param[in]  none
    \param[out] none
    \retval     none
    rcu_periph_clock_enable(RCU_GPIOA);
    /*configure PA8(TIMER0 CH0) as alternate function*/
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_8);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_8);
    gpio_af_set(GPIOA, GPIO_AF_2, GPIO_PIN_8);
    /*configure PA9(TIMER0 CH1) as alternate function*/
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_9);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_9);
    gpio_af_set(GPIOA, GPIO_AF_2, GPIO_PIN_9);
    /*configure PA10(TIMER0 CH2) as alternate function*/
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_10);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_10);
    gpio_af_set(GPIOA, GPIO_AF_2, GPIO_PIN_10);
    /*configure PA11(TIMER0 CH3) as alternate function*/
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_11);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_11);
    gpio_af_set(GPIOA, GPIO_AF_2, GPIO_PIN_11);
    \brief      configure the DMA peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    dma_parameter_struct dma_init_struct;
    /* enable DMA clock */
    rcu_periph_clock_enable(RCU_DMA);
#if 1
    /* initialize DMA channel4 */
    dma_deinit(DMA_CH4);
    /* DMA channel4 initialize */
    dma_init_struct.direction    = DMA_MEMORY_TO_PERIPHERAL;
    dma_init_struct.memory_addr  = (uint32_t)buffer0;
    dma_init_struct.memory_inc   = DMA_MEMORY_INCREASE_ENABLE;
    dma_init_struct.memory_width = DMA_MEMORY_WIDTH_16BIT;
    dma_init_struct.number       = 4;
    dma_init_struct.periph_addr  = (uint32_t)TIMER0_CH0CC;
    dma_init_struct.periph_inc   = DMA_PERIPH_INCREASE_DISABLE;
    dma_init_struct.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;
    dma_init_struct.priority     = DMA_PRIORITY_HIGH;
    dma_init(DMA_CH4,dma_init_struct);
    /* configure DMA mode */
    dma_circulation_enable(DMA_CH4);
    dma_memory_to_memory_disable(DMA_CH4);
    /* enable DMA channel4 */
    dma_channel_enable(DMA_CH4);
#endif
#if 1
    /* initialize DMA channel3 */
    dma_deinit(DMA_CH3);
    dma_init(DMA_CH3,dma_init_struct);
    dma_circulation_enable(DMA_CH3);
    dma_memory_to_memory_disable(DMA_CH3);
    dma_channel_enable(DMA_CH3);
#endif
#if 1
    /* initialize DMA channel2 */
    dma_deinit(DMA_CH1);
    dma_circulation_enable(DMA_CH1);
    dma_memory_to_memory_disable(DMA_CH1);
    dma_channel_enable(DMA_CH1);
#endif
    \brief      configure the TIMER peripheral
    \param[in]  none
    \param[out] none
    \retval     none
   timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    rcu_periph_clock_enable(RCU_TIMER0);
    timer_deinit(TIMER0);
    /* TIMER0 configuration */
    timer_initpara.prescaler         = 83;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 999;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER0,&timer_initpara);
    /* CH0 configuration in PWM0 mode */
    timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;
    timer_ocintpara.outputnstate = TIMER_CCXN_ENABLE;
    timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;
    timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_HIGH;
    timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
    timer_channel_output_config(TIMER0,TIMER_CH_0,&timer_ocintpara);
    timer_channel_output_config(TIMER0,TIMER_CH_1,&timer_ocintpara);
    timer_channel_output_config(TIMER0,TIMER_CH_2,&timer_ocintpara);
    timer_channel_output_config(TIMER0,TIMER_CH_3,&timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_0,120);
    timer_channel_output_mode_config(TIMER0,TIMER_CH_0,TIMER_OC_MODE_TOGGLE);
    timer_channel_output_shadow_config(TIMER0,TIMER_CH_0,TIMER_OC_SHADOW_DISABLE);
    timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_1,80);
    timer_channel_output_mode_config(TIMER0,TIMER_CH_1,TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER0,TIMER_CH_1,TIMER_OC_SHADOW_DISABLE);
    timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_2,80);
    timer_channel_output_mode_config(TIMER0,TIMER_CH_2,TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER0,TIMER_CH_2,TIMER_OC_SHADOW_DISABLE);
    timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_3,80);
    timer_channel_output_mode_config(TIMER0,TIMER_CH_3,TIMER_OC_MODE_PWM0);
    timer_channel_output_shadow_config(TIMER0,TIMER_CH_3,TIMER_OC_SHADOW_DISABLE);
    /* TIMER0 primary output enable */
    timer_primary_output_config(TIMER0,ENABLE);
    /* TIMER0 update DMA request enable */
//    timer_dma_enable(TIMER0,TIMER_DMA_UPD);
//    timer_dma_enable(TIMER0, TIMER_DMA_CH1D);
//    timer_dma_enable(TIMER0, TIMER_DMA_CH2D);
//    timer_dma_enable(TIMER0, TIMER_DMA_CH3D);
    timer_interrupt_enable(TIMER0, TIMER_INT_CH0);
    /* auto-reload preload enable */
    timer_auto_reload_shadow_enable(TIMER0);
    /* TIMER0 counter enable */
    timer_enable(TIMER0);
 楼主| ecm1984 发表于 2021-9-2 10:37 | 显示全部楼层
当计数器的值与 CHxVAL 寄存器的值匹配时, CHxIF 位被置 1 ,如果 CHxIE = 1 则会产生中断,如果 CHxDEN=1 则会产生 DMA 请求。
好像没有看到还需要其他的配置,但是 TIMER比较后,确实没有DMA请求,
昆山友沐 发表于 2021-9-7 12:08 | 显示全部楼层
你好,GD32F330CBT6 好用吗?可以交流一下不?+微信:youmu_pcb
