| 线程退出 线程的退出方式有三种:
 执行完成后隐式退出;
 由线程本身显示调用 pthread_exit (void * retval);函数退出。其中,参数 retval 用于保存线程退出状态
 被其他线程用 pthread_cance (pthread_t thread);函数终止。在某线程中调用此函数,可以终止由参数 thread 指定的线程。
 实例
 #include <stdio.h>
 #include <pthread.h>
 #include <unistd.h>
 pthread_t tidp, tidp2;           // 线程ID
 void *thread1(void *arg)
 int *num;
 num = (int *)arg;     // 存放传递的参数
 printf("I‘m thread1, ID is %u\n",pthread_self());        // 打印线程自己的ID
 printf("Receive parameter is %d \n",*num);               // 打印收到的参数
 printf("I'm waitting to be cancenl!\n");
 sleep(20);                                               // 等待线程2 将它结束
 return (void *)0;                                        // 如果,线程2没有将其结束,返回0
 void *thread2(void *arg)
 int error;
 printf("I'm thread2. I Will to Cancel thread %u\n",tidp);
 error = pthread_cancel(tidp);         // 取消线程 1
 if(error<0)
 printf("Cancel thread %u failed!\n",tidp);
 return (void *)-1;
 else
 printf("Cancel thread %u sucessfully! It will not return 0!\n",tidp);  // 因为线程2将线程1取消了,所以线程1不能正常返回0
 return 0;
 int main(int argc, char *argv[])
 int error;
 void* r_num1,*r_num2;
 int test = 4;
 int *attr = &test;
 error = pthread_create(&tidp,NULL,thread1,(void *)attr);   // 创建新线程,并传递参数(void *)attr
 if(error)
 printf("pthread_create is created is not created ... \n");
 return -1;
 error = pthread_create(&tidp2,NULL,thread2,NULL);
 if(error)
 return -1;
 error = pthread_join(tidp2,&r_num2);           // 阻塞在此处,直到线程2返回
 error = pthread_join(tidp,&r_num1);            // 阻塞在此处,直到线程1返回
 sleep(1);
 printf("Thread1 return %d\n",(int)r_num1);  // 线程1的返回值,如果线程1被线程2 取消,则返回值不是0
 printf("Thread2 return %d\n",(int)r_num2);  // 线程2的返回值
 return 0;
