SC16IS750实现全双工UART问题
3244|1
 楼主| NICKY99 发表于 2012-3-14 17:16 | 显示全部楼层 |阅读模式
各位好!
以下为SC16IS750程序,此程序要实现全双工UART,但以下程序只有发送正常,接收不正常,请各位指出问题所在,谢谢!
//         sc16is750
void Init_750SPI(void)
  DDRB|=(1<<CS_MOSI)|(1<<CS_SCK)|(1<<CS_CS);
  SPCR|=(1<<SPE)|(1<<MSTR)|(1<<SPR1)|(1<<SPR0);  //SPI模式0
  SPSR = 0x00;      //setup SPI
  SET_BIT(PORTB,CS_DRDY);
  SET_BIT(PORTB,CS_MISO);
void Wreg(unsigned char addr,unsigned char regdata)  //写寄存器
CLR_BIT(PORTE,COM_CS);
SPDR = (addr<<3);
while(!(SPSR&(1<<SPIF)));
SPDR = regdata;
SET_BIT(PORTE,COM_CS);
unsigned char Rreg(unsigned char addr)  //读寄存器
    SPDR = (0x80|(addr<<3));
    SPDR = 0x00;//启动SPI
    return SPDR;
unsigned char ReadData(void)
    SPDR =(0x80|( (RHR<<3));
    SPDR = 0x00;//启动SPI
    return SPDR;
void Spi_Send(unsigned char addr,unsigned char senddata)
SPDR = (addr<<3);
SPDR = senddata;
void Spi_sendstring(unsigned char *sdata,unsigned int amount)
  SPDR = (THR<<3);       // 传送命令到SPI寄存器
  while(amount)
      SPDR = *sdata; sdata++;
      amount--;
void Init_750(void)
  CLR_BIT(PORTC,COM_RST);
  _delay_ms(20);
SET_BIT(PORTC,COM_RST);
  _delay_ms(10);
Wreg(IOIntEna,0x00);      //使能IO中断
  _delay_ms(10);
Wreg (LCR, 0x80);// 0x80 to program baud rate
  _delay_ms(10);
Wreg (DLL, 0x06);// 0x30=19.2K, 0x08 =115.2K with X1=14.7456 MHz      0x60=1200 with x1=1.8432MHz
  _delay_ms(10);
Wreg (DLH, 0x00);// divisor = 0x0008 for 115200 bps
  _delay_ms(10);
//Wreg (LCR, 0xBF);// access EFR register
//Wreg (EFR, 0X10);// enable enhanced registers
Wreg (LCR, 0x03);// 8 data bit, 1 stop bit, no parity
  _delay_ms(10);
Wreg (FCR, 0x06);// reset TXFIFO, reset RXFIFO, non FIFO mode
  _delay_ms(10);
Wreg (FCR, 0xb7);// enable FIFO mode
  _delay_ms(10);
Wreg (IER, 0x05);//
 楼主| NICKY99 发表于 2012-3-15 09:35 | 显示全部楼层
