GD32VF103_Demo_Suites提供了一个ADC例程,通过TIMER触发LCD显示电压曲线 路径为:GD32VF103_Demo_Suites_V1.0.2\GD32VF103V_EVAL_Demo_Suites\Projects\07_ADC_conversion_triggered_by_timer 通过修改代码添加DAC功能可以很方便的看到DAC输出 原来的例程通过ADC采集电位器分压后的电压 修改后的例程将DAC输出连接到电位器的输出端 电位器尽量调节到中心位置,即1/VCC电平处 添加DAC初始化代码 - void dac_config(void)
- dac_deinit();
- /* configure the DAC0 */
- dac_trigger_disable(DAC0);
- dac_wave_mode_config(DAC0, DAC_WAVE_DISABLE);
- dac_output_buffer_enable(DAC0);
- /* enable DAC0 and set data */
- dac_enable(DAC0);
[img=15,15]data:image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==" >
开始DAC和对应GPIO的时钟 - rcu_periph_clock_enable(RCU_GPIOA);
- rcu_periph_clock_enable(RCU_DAC);
配置对应的GPIO为DAC功能 - /* once enabled the DAC, the corresponding GPIO pin is connected to the DAC converter automatically */
- gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
在主循环里添加修改输出电压的代码 - dac_val+=100;
- dac_data_set(DAC0, DAC_ALIGN_12B_L, dac_val<<4);
运行后效果如下 [img=480,0]http://bbs.**/data/attachment/forum/201910/14/120437vtbiczzykjibynbi.gif" >
完整 main.c代码 - /*!
- \file main.c
- \brief ADC conversion triggered by timer
- \version 2019-6-5, V1.0.0, firmware for GD32VF103
- Copyright (c) 2019, GigaDevice Semiconductor Inc.
- Redistribution and use in source and binary forms, with or without modification,
- are permitted provided that the following conditions are met:
- 1. Redistributions of source code must retain the above copyright notice, this
- list of conditions and the following disclaimer.
- 2. Redistributions in binary form must reproduce the above copyright notice,
- this list of conditions and the following disclaimer in the documentation
- and/or other materials provided with the distribution.
- 3. Neither the name of the copyright holder nor the names of its contributors
- may be used to endorse or promote products derived from this software without
- specific prior written permission.
- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
- WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
- IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
- INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
- NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
- PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
- WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- OF SUCH DAMAGE.
- #include "gd32vf103.h"
- #include "gd32vf103v_eval.h"
- #include "gd32vf103v_lcd_eval.h"
- #include "systick.h"
- #define BOARD_ADC_CHANNEL ADC_CHANNEL_13
- #define ADC_GPIO_PORT GPIOC
- #define ADC_GPIO_PIN GPIO_PIN_3
- #define X_START 2
- #define Y_START 10
- #define Y_DEALT 20
- uint8_t gd_companyname_string[]={"GigaDevice Semiconductor Inc."} ;
- uint8_t gd_mcu_string[]={" -- GD32VF103 Series MCU -- "} ;
- uint8_t gd_evalboard_string[]={" GD32V103V_EAVL "} ;
- uint8_t gd_demoname_string[]={" ADC triggered by TIMER "} ;
- uint8_t gd_operation_tip_string[]={" Please adjust the VR1 ! "} ;
- uint16_t device_code;
- char_format_struct char_format;
- __IO uint16_t ad_value[220];
- uint16_t dac_val = 0;
- void test_display_init(void);
- void diaplay_adc_value(void);
- void flash_led(int times);
- void rcu_config(void);
- void gpio_config(void);
- void dma_config(void);
- void adc_config(void);
- void timer_config(void);
- void dac_config(void);
- \brief main function
- \param[in] none
- \param[out] none
- \retval none
- int main(void)
- /* init test status led */
- gd_eval_led_init(LED1);
- gd_eval_led_init(LED2);
- gd_eval_led_init(LED3);
- gd_eval_led_init(LED4);
- /* flash led for test */
- flash_led(3);
- /* system clocks configuration */
- rcu_config();
- /* GPIO configuration */
- gpio_config();
- /* DMA configuration */
- dma_config();
- /* ADC configuration */
- adc_config();
- /* RCU configuration */
- timer_config();
- /* configure the EXMC access mode */
- exmc_lcd_init();
- /* read the LCD Controller device code:(0x8989) */
- device_code = lcd_register_read(0x0000);
- /* initialize the LCD */
- lcd_init();
- /* clear the LCD screen */
- lcd_clear(LCD_COLOR_WHITE);
- /* LCD content initialize */
- test_display_init();
- /* configure the DAC */
- dac_config();
- while(1){
- /* TIMER1 counter enable */
- timer_enable(TIMER1);
- /* test on channel1 transfer complete flag */
- while( !dma_flag_get(DMA0,DMA_CH0, DMA_FLAG_FTF));
- /* clear channel1 transfer complete flag */
- dma_flag_clear(DMA0,DMA_CH0, DMA_FLAG_FTF);
- /* TIMER1 counter disable */
- timer_disable(TIMER1);
- dac_val+=100;
- diaplay_adc_value();
- \brief configure the DAC
- \param[in] none
- \param[out] none
- \retval none
- dac_deinit();
- dac_enable(DAC0);
- \brief LCD content initialize
- \param[in] none
- \param[out] none
- \retval none
- void test_display_init( void )
- int i;
- /* configure char format */
- char_format.char_color = LCD_COLOR_BLUE;
- char_format.bk_color = LCD_COLOR_WHITE;
- char_format.direction = CHAR_DIRECTION_VERTICAL;
- char_format.font = CHAR_FONT_8_16;
- /* draw character on LCD screen */
- for(i = 0; i < sizeof(gd_companyname_string)-1; i++){
- lcd_char_display((X_START+8*i), Y_START+0*Y_DEALT, *(gd_companyname_string+i),char_format);
- for(i = 0; i < sizeof(gd_mcu_string)-1; i++){
- lcd_char_display((X_START+8*i), Y_START+1*Y_DEALT, *(gd_mcu_string+i),char_format);
- for(i = 0; i < sizeof(gd_evalboard_string)-1; i++){
- lcd_char_display((X_START+8*i), Y_START+2*Y_DEALT, *(gd_evalboard_string+i),char_format);
- for(i = 0; i < sizeof(gd_demoname_string)-1; i++){
- lcd_char_display((X_START+8*i), Y_START+3*Y_DEALT, *(gd_demoname_string+i),char_format);
- for(i = 0; i < sizeof(gd_operation_tip_string)-1; i++){
- lcd_char_display((X_START+8*i), Y_START+4*Y_DEALT, *(gd_operation_tip_string+i),char_format);
- lcd_hline_draw(X_START+6,110,310,LCD_COLOR_BLUE,1);
- lcd_vline_draw(X_START+6,X_START+6+220,310,LCD_COLOR_BLUE,1);
- for(i = 0;i < 4;i ++){
- lcd_vline_draw(X_START+6-4,X_START+6,110+i*50,LCD_COLOR_BLUE,1);
- lcd_vline_draw(X_START+6-4,X_START+6,110+25+i*50,LCD_COLOR_BLUE,1);
- \brief display ADC value
- \param[in] none
- \param[out] none
- \retval none
- int ix,iy,i;
- int deta = 200 /4 * 3.3;
- for(ix = X_START + 6 + 1,i = 0;ix < X_START + 6 +220;ix++,i++){
- for(iy = 130;iy < 310-1;iy++){
- if(iy == (310 - ad_value[ i ] * deta / 0x0FFF)){
- /* set the pixel */
- lcd_point_set(ix,iy,LCD_COLOR_BLUE); //lcd_point_set
- }else{
- lcd_point_set(ix,iy,LCD_COLOR_WHITE);
- \brief test status led
- \param[in] times: the flash times of leds
- \param[out] none
- \retval none
- int i;
- for(i = 0;i < times;i ++){
- /* insert 200 ms delay */
- delay_1ms(200);
- /* turn on led */
- gd_eval_led_on(LED1);
- gd_eval_led_on(LED2);
- gd_eval_led_on(LED3);
- gd_eval_led_on(LED4);
- delay_1ms(200);
- /* turn off led */
- gd_eval_led_off(LED1);
- gd_eval_led_off(LED2);
- gd_eval_led_off(LED3);
- gd_eval_led_off(LED4);
- \brief configure the different system clocks
- \param[in] none
- \param[out] none
- \retval none
- /* enable GPIOA clock */
- rcu_periph_clock_enable(RCU_GPIOC);
- /* enable ADC clock */
- rcu_periph_clock_enable(RCU_ADC0);
- /* enable DMA0 clock */
- rcu_periph_clock_enable(RCU_DMA0);
- /* enable timer1 clock */
- rcu_periph_clock_enable(RCU_TIMER1);
- /* config ADC clock */
- rcu_adc_clock_config(RCU_CKADC_CKAPB2_DIV8);
- /* enable the clock of peripherals */
- \brief configure the GPIO peripheral
- \param[in] none
- \param[out] none
- \retval none
- /* config the GPIO as analog mode */
- gpio_init(ADC_GPIO_PORT, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, ADC_GPIO_PIN);
- \brief configure the DMA peripheral
- \param[in] none
- \param[out] none
- \retval none
- /* ADC_DMA_channel configuration */
- dma_parameter_struct dma_data_parameter;
- /* ADC DMA_channel configuration */
- dma_deinit(DMA0, DMA_CH0);
- /* initialize DMA single data mode */
- dma_data_parameter.periph_addr = (uint32_t)(&ADC_RDATA(ADC0));
- dma_data_parameter.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
- dma_data_parameter.memory_addr = (uint32_t)(ad_value);
- dma_data_parameter.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
- dma_data_parameter.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;
- dma_data_parameter.memory_width = DMA_MEMORY_WIDTH_16BIT;
- dma_data_parameter.direction = DMA_PERIPHERAL_TO_MEMORY;
- dma_data_parameter.number = 220;
- dma_data_parameter.priority = DMA_PRIORITY_HIGH;
- dma_init(DMA0, DMA_CH0, &dma_data_parameter);
- dma_circulation_enable(DMA0, DMA_CH0);
- /* enable DMA channel */
- dma_channel_enable(DMA0, DMA_CH0);
- \brief configure the ADC peripheral
- \param[in] none
- \param[out] none
- \retval none
- /* reset ADC */
- adc_deinit(ADC0);
- /* ADC mode config */
- adc_mode_config(ADC_MODE_FREE);
- /* ADC contineous function enable */
- adc_special_function_config(ADC0, ADC_CONTINUOUS_MODE, DISABLE);
- /* ADC scan mode disable */
- adc_special_function_config(ADC0, ADC_SCAN_MODE, DISABLE);
- /* ADC data alignment config */
- adc_data_alignment_config(ADC0, ADC_DATAALIGN_RIGHT);
- /* ADC channel length config */
- adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 1);
- /* ADC regular channel config */
- adc_regular_channel_config(ADC0, 0, BOARD_ADC_CHANNEL, ADC_SAMPLETIME_55POINT5);
- /* ADC trigger config */
- adc_external_trigger_source_config(ADC0, ADC_REGULAR_CHANNEL, ADC0_1_EXTTRIG_REGULAR_T1_CH1);
- adc_external_trigger_config(ADC0, ADC_REGULAR_CHANNEL, ENABLE);
- /* enable ADC interface */
- adc_enable(ADC0);
- delay_1ms(1);
- /* ADC calibration and reset calibration */
- adc_calibration_enable(ADC0);
- /* ADC DMA function enable */
- adc_dma_mode_enable(ADC0);
- \brief TIMER configuration function
- \param[in] none
- \param[out] none
- \retval none
- timer_oc_parameter_struct timer_ocintpara;
- timer_parameter_struct timer_initpara;
- timer_deinit(TIMER1);
- /* TIMER1 configuration */
- timer_initpara.prescaler = 5;
- timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
- timer_initpara.counterdirection = TIMER_COUNTER_UP;
- timer_initpara.period = 199;
- timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
- timer_initpara.repetitioncounter = 0;
- timer_init(TIMER1,&timer_initpara);
- /* CH1 configuration in PWM mode1 */
- timer_channel_output_struct_para_init(&timer_ocintpara);
- timer_ocintpara.ocpolarity = TIMER_OC_POLARITY_LOW;
- timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
- timer_channel_output_config(TIMER1, TIMER_CH_1, &timer_ocintpara);
- timer_channel_output_pulse_value_config(TIMER1, TIMER_CH_1, 100);
- timer_channel_output_mode_config(TIMER1, TIMER_CH_1, TIMER_OC_MODE_PWM1);
- timer_channel_output_shadow_config(TIMER1, TIMER_CH_1, TIMER_OC_SHADOW_DISABLE);
- /* auto-reload preload enable */
- timer_auto_reload_shadow_enable(TIMER1);
