assert_param始终不明白这个函数是怎么检查参数的,郁闷!
3264|3
 楼主| pingandpeng 发表于 2012-3-16 15:30 | 显示全部楼层 |阅读模式
assert_param 固件库里有好多这个函数 可是我总是不明白它具体是怎么检查参数的,呜呜....
lai832 发表于 2012-3-16 15:46 | 显示全部楼层
也刚学:
看平台不同,全固件库搜:
"assert_param"
发现N多用"assert_param(....."
的几个:   #define assert_param(expr) ....
其实就两个:
在stm32f10x_conf.h的69行和73行
#ifdef  USE_FULL_ASSERT
  * @brief  The assert_param macro is used for function's parameters check.
  * @param  expr: If expr is false, it calls assert_failed function which reports
  *         the name of the source file and the source line number of the call
  *         that failed. If expr is true, it returns no value.
  * @retval None
  #define assert_param(expr) ((expr) ? (void)0 : assert_failed((uint8_t *)__FILE__, __LINE__))
/* Exported functions ------------------------------------------------------- */
  void assert_failed(uint8_t* file, uint32_t line);
#else
  #define assert_param(expr) ((void)0)
#endif /* USE_FULL_ASSERT */
但:void assert_failed(uint8_t* file, uint32_t line);
这个是库里全程的Main定义的一个函数:(如下)
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
主要是我看不懂:
后面的参数是怎来的
lxyppc 发表于 2012-3-16 16:48 | 显示全部楼层
编译器预定义宏
__FILE__ 当前文件名
__LINE__ 当前行号
还有__TIME__, __DATE__, __func__等
不同的编译器可能支持的宏不同,可以用这些宏做为关键字在google中进行搜索
lai832 发表于 2012-3-16 17:54 | 显示全部楼层
谢:谢,这样主就是一个错误,或是信息提示用...下班88
