Description
The STEVAL-ETH001V1 servo drive evaluation board has been developed to
address three-phase PMSM applications oriented to multi-axial position control and
connectivity.
The evaluation board embeds a motor control power stage, a digital actuation section
and a power management section.
The motor control power stage hosts the STDRIVE101 half-bridge gate driver and
six STH270N8F7-2 power MOSFETs, featuring real-time connectivity with Ethercat
communication protocol supported by the NETX90 network controller, whereas the
digital actuation section hosts an industrial IO management section with CLT03-2Q3
(input) and IPS160H (output). The power management section is powered by L7987,
L7805CD2T-TR and LD39150DT33-R devices.
The STEVAL-ETH001V1 is equipped with two RJ45 connectors for daisy chain
connection and an RS485 interface for digital encoder or host connection powered by
ST3485EI. For a better noise immunity, the PCB is characterized by a 6-layer stack
and an insulated track for supply line and ground. A quadrature encoder interface
with index is also present.
