[技术问答] 各位CRC都是怎么用的?
3467|8
 楼主| andygirl 发表于 2021-10-25 11:05 | 显示全部楼层 |阅读模式
板子:M471
例程:CRC_CCITT
main函数部分
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*  MAIN function        */
  3. /*---------------------------------------------------------------------------------------------------------*/
  4. int main(void)
  5. {
  6.     const uint16_t u16CRCSrcPattern[] = {0x3231, 0x3433, 0x3635, 0x3837};
  7.     uint32_t i, u32TargetChecksum = 0xA12B, u32CalChecksum = 0;
  8.     /* Init System, peripheral clock and multi-function I/O */
  9.     SYS_Init();
  10.     /* Init UART0 for printf */
  11.     UART0_Init();
  12.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
  13.     printf("+---------------------------------------------+\n");
  14.     printf("|    CRC-CCITT Polynomial Mode Sample Code    |\n");
  15.     printf("+---------------------------------------------+\n\n");
  16.     printf("# Calculate [0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38] CRC-CCITT checksum value.\n");
  17.     printf("    - Seed value is 0xFFFF             \n");
  18.     printf("    - CPU write data length is 16-bit \n");
  19.     printf("    - Checksum complement disable    \n");
  20.     printf("    - Checksum reverse disable       \n");
  21.     printf("    - Write data complement disable  \n");
  22.     printf("    - Write data reverse disable     \n");
  23.     printf("    - Checksum should be 0x%X        \n\n", u32TargetChecksum);
  24.     /* Configure CRC controller for CRC-CCITT CPU mode */
  25.     CRC_Open(CRC_CCITT, 0, 0xFFFF, CRC_CPU_WDATA_16);
  26.     /* Start to execute CRC-CCITT operation */
  27.     for(i = 0; i < sizeof(u16CRCSrcPattern) / sizeof(u16CRCSrcPattern[0]); i++)
  28.     {
  29.         CRC_WRITE_DATA((u16CRCSrcPattern[i]));
  30.     }
  31.     /* Get CRC-CCITT checksum value */
  32.     u32CalChecksum = CRC_GetChecksum();
  33.     printf("CRC checksum is 0x%X ... %s.\n", u32CalChecksum, (u32CalChecksum == u32TargetChecksum) ? "PASS" : "FAIL");
  34.     /* Disable CRC function */
  35.     CLK_DisableModuleClock(CRC_MODULE);
  36.     while(1);
  37. }
虽然跑了例程,
但是对CRC部分还是不怎么理解
之前做CRC校验,会有个CRC函数,通过校验函数来判断数据的正确性。
像这种CRC的例程,其目的是校验数据么?怎么操作的。
另外,CRC的这几个例程,CCITT是个什么意思?
可能在高手看来,我的问题很简单,但我确实没搞明白,希望有时间的高手可以帮忙解答
skyred 发表于 2021-10-26 15:10 | 显示全部楼层
没用过CRC~~
huahuagg 发表于 2021-10-26 22:59 | 显示全部楼层
这个就要去先学习CRC是什么了
huahuagg 发表于 2021-10-26 23:03 | 显示全部楼层
https://www.21ic.com/app/mcu/201202/106263.htm
便携手到老 发表于 2021-10-27 18:34 | 显示全部楼层
现在还用CRC校验吗?不是一直使用的是AES128的加密算法吗?CRC也不是很稳定吧?
littlelida 发表于 2021-11-5 10:47 | 显示全部楼层
感谢提供资料,这个是理论学习的
 楼主| andygirl 发表于 2021-11-8 13:33 | 显示全部楼层
学习一下
jasontu 发表于 2021-11-10 09:38 | 显示全部楼层
https://zhidao.baidu.com/question/71828357.html
CRC 拿来是通信封包的校验。
AES128是资料的加密,
2个用途不是相同的。
jcky001 发表于 2021-11-10 11:05 | 显示全部楼层
CRC,没用过啊
