GD32F103C8测试CAN回环模式发送一直pending
2430|0
 楼主| duware 发表于 2021-10-27 15:38 | 显示全部楼层 |阅读模式
GD32F103C8,测试CAN通信,用CAN总线分析仪测试,发现收发异常。用回环模式测试,发现发送一直处于pending。
void RCC_Configuration(void)
    SystemInit();
    rcu_periph_clock_enable(RCU_GPIOA);
    rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_AF);
    rcu_periph_clock_enable(RCU_CAN0);
    rcu_periph_clock_enable(RCU_TIMER0);
    rcu_periph_clock_enable(RCU_TIMER1);
    rcu_periph_clock_enable(RCU_TIMER2);
    rcu_periph_clock_enable(RCU_TIMER3);
void GPIO_Configuration(void)
    //LED
    gpio_init(LED_PORT, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, LED_PIN);
   //CAN
    gpio_init(GPIOA,GPIO_MODE_IPU,GPIO_OSPEED_50MHZ,GPIO_PIN_11);
    gpio_init(GPIOA,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_12);
void CAN_Configuration(void)
    can_parameter_struct can_parameter={0};
    can_filter_parameter_struct can_filter={0};
    can_struct_para_init(CAN_INIT_STRUCT, &can_parameter);
    can_struct_para_init(CAN_INIT_STRUCT, &can_filter);
    can_deinit(CAN0);
    can_parameter.time_triggered = DISABLE;
    can_parameter.auto_bus_off_recovery = DISABLE;
    can_parameter.auto_wake_up = DISABLE;
    can_parameter.no_auto_retrans = DISABLE;
    can_parameter.rec_fifo_overwrite = DISABLE;
    can_parameter.trans_fifo_order = DISABLE;
    can_parameter.working_mode = CAN_LOOPBACK_MODE;//CAN_NORMAL_MODE;
    can_parameter.resync_jump_width = CAN_BT_SJW_1TQ;
    can_parameter.time_segment_1 = CAN_BT_BS1_5TQ;
    can_parameter.time_segment_2 = CAN_BT_BS2_3TQ;
    can_parameter.prescaler = 24;//250k
    /* initialize CAN */
    can_init(CAN0, &can_parameter);
    /* initialize filter */
    can_filter.filter_number=0;
    can_filter.filter_mode = CAN_FILTERMODE_MASK;
    can_filter.filter_bits = CAN_FILTERBITS_32BIT;
    can_filter.filter_list_high = 0x0000;
    can_filter.filter_list_low = 0x0000;
    can_filter.filter_mask_high = 0x0000;
    can_filter.filter_mask_low = 0x0000;
    can_filter.filter_fifo_number = CAN_FIFO0;
    can_filter.filter_enable = ENABLE;
    can_filter_init(&can_filter);
    can_interrupt_enable(CAN0, CAN_INT_RFNE0);
int main(void)
     can_trasnmit_message_struct transmit_message;
     uint32_t timeout = 0xFFFF;
     uint8_t transmit_mailbox = 0;
     char *buffer="Hello!!!";
     unsigned char flag=0;
     unsigned char error=0;
     uint32_t clk=0;
     RCC_Configuration();
     GPIO_Configuration();
     Timer_Configuration();
     NVIC_Configuration();
     transmit_message.tx_sfid = 0;
     transmit_message.tx_efid = 0x00;
     transmit_message.tx_ft = CAN_FT_DATA;
     transmit_message.tx_ff = CAN_FF_STANDARD;
     transmit_message.tx_dlen = 2;
     transmit_message.tx_data[0]=0x5A;
     transmit_message.tx_data[1]=0xA5;
     while(1)
         fwdgt_counter_reload();
         if(SYS_TICK & g_cCMDFlag)
             g_cCMDFlag&=~SYS_TICK;
             flag=1-flag;
             if(flag)
               gpio_bit_write(LED_PORT,LED_PIN,SET);
             else
               gpio_bit_write(LED_PORT,LED_PIN,RESET);
             timeout = 0xFFFF;
             transmit_mailbox = can_message_transmit(CAN0, &transmit_message);
             while((CAN_TRANSMIT_OK != can_transmit_states(CAN0, transmit_mailbox)) && (0 != timeout))
                timeout--;
             error=can_error_get(CAN0);
             error=can_transmit_error_number_get(CAN0);
     return 0;
用can_error_get(CAN0)和can_transmit_error_number_get(CAN0),返回值都是0,判断不出原因。
在另外一块GD32F190C8板子上,回环模式能正常收发,切换到正常工作模式,收发有问题,发送会报错。
