[研电赛技术支持] gd32的定时器比较模式的配置问题
2540|2
 楼主| a864894787 发表于 2021-11-4 09:37 | 显示全部楼层 |阅读模式
想使用定时器的比较反转模式,按照例程进行配置,发现比较模式不起作用,io的改变只是因为定时器的溢出进行的io反转,求各位大神指导!
void gpio_config(void)
    rcu_periph_clock_enable(RCU_GPIOA);
    rcu_periph_clock_enable(RCU_AF);
    /*configure PA1(TIMER1 CH1) as alternate function*/
    gpio_init(GPIOA, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_1);
    \brief      configure the timer peripheral
    \param[in]  none
    \param[out] none
    \retval     none
void timer_config(void)
    TIMER1 configuration: output compare toggle mode:
    TIMER1CLK = systemcoreclock / 5400 = 20K,
    CH1 update rate = TIMER1 counter clock / CH1VAL = 20000/4000 = 5 Hz
    timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    rcu_periph_clock_enable(RCU_TIMER1);
    timer_deinit(TIMER1);
    /* TIMER1 configuration */
    timer_initpara.prescaler         = 108-1;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 9999;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER1,&timer_initpara);
     /* CH1 configuration in OC TOGGLE mode */
    timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;
    timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;
    timer_ocintpara.outputnstate = TIMER_CCXN_DISABLE;
    timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_LOW;
    timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
    timer_channel_output_config(TIMER1,TIMER_CH_1,&timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_1,4999);
    timer_channel_output_mode_config(TIMER1,TIMER_CH_1,TIMER_OC_MODE_TOGGLE);
    timer_channel_output_shadow_config(TIMER1,TIMER_CH_1,TIMER_OC_SHADOW_DISABLE);
    /* auto-reload preload enable */
    timer_auto_reload_shadow_enable(TIMER1);
    timer_enable(TIMER1);
int main(void)
        int i=1;
        rcu_apb2_clock_config(RCU_APB2_CKAHB_DIV1);
        rcu_periph_clock_enable(RCU_GPIOC);
        systick_config();
        gpio_init(GPIOC, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_13);
        USART0_init(115200U);
        printf("system running -------\r\n");
        gpio_config();
    timer_config();
    while(1)
                        TIMER_CAR(TIMER1) = 3000;
                        TIMER_CH1CV(TIMER1) = 2000;
                        printf("key press\r\n");
                        delay_ms(1000);
                        gpio_bit_set(GPIOC, GPIO_PIN_13);
                        delay_ms(1000);
                        gpio_bit_reset(GPIOC, GPIO_PIN_13);
    return 0;
sadicy 发表于 2021-11-11 10:43 | 显示全部楼层
帮顶,看不出毛病
lifeforrent 发表于 2021-11-11 19:14 | 显示全部楼层
在while(1)中加入下面代码:
while(1)
                delay_1ms(10);
                if(i>10000){
                        i=0;
                }else{
                        i=i+2000;
        TIMER_CH1CV(TIMER1)= i;
定时器溢出不会导致电平翻转,其实比较翻转已经发生了,只是你这种方法用示波器看不到而已,你配置的定时器周期是10ms,所以在while循环中10ms更改一次比较值,每次比较值设置为不同的比较值,就可以在示波器上观察到波形变化。
