usage page(undefined)以及usage(1)、usage(2)是什么意思啊?
3441|1
 楼主| lzqxs89 发表于 2012-3-19 17:06 | 显示全部楼层 |阅读模式
char code Pc_Report_Descriptor[] = {
0x05, 0x01,      // Usage Page(Generic Desktop Controls )
0x09, 0x04,      // Usage(Joystick)
0xA1, 0x01,      // Collection(Application)
0xA1, 0x02,      //   Collection(Logical)
0x15, 0x00,      //     Logical Minimum(0x00)
0x26, 0xFF, 0x00,   //     Logical Maximum(0xFF)
0x35, 0x00,       //     Physical Minimum(0x00)
0x46, 0xFF, 0x00,   //     Physical Maximum(0xFF)
0x75, 0x08,      //     Report Size(0x08)
0x95, 0x04,      //     Report Count(0x04)
0x09, 0x30,         //    Usage(X)
0x09, 0x31,      //    Usage(Y)
0x09, 0x32,      //     Usage(Z)
0x09, 0x35,      //     Usage(Rz)
0x81, 0x02,      //     Input(Data, Variable, Absolute, No Wrap, Linear, Preferred State, No Null Position, Bit Field)
0x25, 0x07,      //     Logical Maximum(0x07)
0x46, 0x3B, 0x01,   //     Physical Maximum(0x013B)
0x75, 0x04,      //     Report Size(0x04)
0x95, 0x01,      //     Report Count(0x01)
0x65, 0x14,      //     Unit(Degrees)
0x09, 0x39,      //     Usage(Hat switch)
0x81, 0x42,      //     Input(Data, Variable, Absolute, No Wrap, Linear, Preferred State, Null State, Bit Field)
0x65, 0x00,      //     Unit(None)
0x25, 0x01,      //     Logical Maximum(0x01)
0x45, 0x01,      //     Physical Maximum(0x01)
0x75, 0x01,      //     Report Size(0x01)
0x95, 0x0d,      //     Report Count(0x0C) * 13
0x05, 0x09,      //     Usage Page(Button)
0x19, 0x01,      //     Usage Minimum(0x01)
0x29, 0x0d,      //     Usage Maximum(0x0C) * 13
0x06, 0x00, 0xFF,   //     Usage Page(Undefined)
0x95, 0x0f,      //     Report Count(0x10)   * 15
0x09, 0x01,      //     Usage(1)
0xC0,        //   End Collection
0x95, 0x08,      //     Report Count(0x07) * 8
0x09, 0x02,      //     Usage(2)
0x91, 0x02,      //     Output(Data, Variable, Absolute, No Wrap, Linear, Preferred State, No Null Position, Non VolatileBit Field)
 楼主| lzqxs89 发表于 2012-3-19 17:10 | 显示全部楼层
usage(1)是指usage page(undefined)里面的不?还是哪个 usage page里面的啊,大家帮忙看看啊!我才刚刚开始看USB很多都不懂,求前辈们指教!
