CY6936 AVR
3070|4
 楼主| 77114810 发表于 2012-3-20 11:13 | 显示全部楼层 |阅读模式
接收程序:
#include <iom128v.h>
#include <macros.h>
#include "LpRegs.h"
#define CLR_SS  PORTB&=~BIT(0)
#define SET_SS  PORTB|=BIT(0)
#define F_CPU 7372800
#define CYCLES_PER_US ((F_CPU+500000)/1000000)
unsigned char cyrf6936_recv_buf[];
void delay_us(unsigned short time_us)//延时部分
        unsigned short delay_loops;
        register unsigned short i;
        delay_loops = (time_us+3)/5*CYCLES_PER_US;
        for (i=0; i < delay_loops; i++) {};
void delay_ms(unsigned char time_ms)
unsigned short int i;
        for (i=0; i < 10; i++) {delay_us(100);}
return;
void Delay_s(unsigned char Times)
unsigned char i;
for (i=0; i<Times; i++)
{  delay_ms(250);
    delay_ms(250);
    delay_ms(250);
    delay_ms(250);
void spi_init(void) //spi部分
   SPCR=0x50;
   SPSR = 0x00;
void SpiWriteByte(unsigned char byte)
   SPDR = byte;
   while (!(SPSR & 0x80));
   byte = SPDR;
unsigned char SpiReadByte(void)
   SPDR = 0x00;
   return SPDR;
void write_byte(unsigned char addr,unsigned char data)
   addr = addr|0x80;
   CLR_SS;
   SpiWriteByte(addr);
   SpiWriteByte(data);
   SET_SS;
unsigned char read_byte(unsigned char addr)
   unsigned char buffer;
   CLR_SS;
   SpiWriteByte(addr);
   buffer = SpiReadByte();
   SET_SS;
   return buffer;
void MyRadioInit()    //cy6936的初始化
    SET_SS;
    write_byte(MODE_OVERRIDE_ADR, RST);
    write_byte(AUTO_CAL_TIME_ADR, AUTO_CAL_TIME_MAX);
    write_byte(AUTO_CAL_OFFSET_ADR, AUTO_CAL_OFFSET_MINUS_4);
    write_byte(IO_CFG_ADR, IRQ_POL);
    write_byte(XTAL_CFG_ADR, 0x08);
    write_byte(RX_CFG_ADR,
                ((RX_CFG_RST | FASTTURN_EN | LNA_EN ) & ~( HI | RXOW_EN | AUTO_AGC_EN)));
    write_byte(0x06,0x4A);
write_byte(TX_OFFSET_LSB_ADR, 0x55);
    write_byte(TX_OFFSET_MSB_ADR, 0x05);
    write_byte(TX_CFG_ADR, TX_CFG_RST | DATMODE_8DR);
void main(void)
  PORTB=PORTB|0b11111111;
  DDRB=0b11110111;
   DDRD=0b11111010;
  PORTD=0xff;
  PORTE=0xFF;
  DDRE=0b11111111;
  spi_init();
  MyRadioInit();
   write_byte(0x00,0x48);
  write_byte(0x22,0xB7);
  write_byte(0x22,0x8F);
  write_byte(0x22,0x2B);
  write_byte(0x22,0x01);
  write_byte(0x22,0xEF);
  write_byte(0x22,0x76);
  write_byte(0x22,0x0D);
  while(1)
    unsigned char RxState;
    unsigned char i,NewData,Temp,Temp2,Temp3,Temp4,Number;
NewData=0;
    Number=0;
     MyRadioInit();
write_byte(0x05,0x80);
  Delay_s(100);
while((!NewData)&&(Number<10))
  Number++;
  Temp=read_byte(0x07);      //读取RX_IRQ_STATUS_ADR
  if(!read_byte(0x05))       //RX_GO发生了变化,变为0,自动退出接收状态
   Temp2=read_byte(0x08);  //读取RX_STATUS_ADR  RX_GO自动清零后需要读一下
   if((Temp&(0x02))&&(!((Temp)&(0x01))))   //如果RXC IRQ为1  且RXE IRQ为0
      PORTE&=~BIT(4);
     Delay_s(50);
     PORTE|=BIT(4);
     Delay_s(50);
    if(((read_byte(0x07))&0x01))          //如果第二次读RXE为1  有错误发生
     write_byte(0x07,0x80);  //对RXOW IRQ写1 读receive buffer 之前要写1
     Temp3=read_byte(0x09);
     for(i=0;i<Temp3;i++)
      Temp4=read_byte(0x21);        //读出错误的数据 长度为RX_COUNT_ADR
     NewData=0;
    PORTE&=~BIT(7);
     Delay_s(50);
     PORTE|=BIT(7);
     Delay_s(50);
    else        //无错误发生,读取有效数据
  PORTE&=~BIT(3);
     Delay_s(50);
     PORTE|=BIT(3);
     Delay_s(50);
     for (i=0; i<16; i++)
      cyrf6936_recv_buf=read_byte(0x21);    //读数据
     NewData=1;    //标志位置1  把收到的数据通过USB发送到上位机上去
   else if((Temp&(0x02))&&(((Temp)&(0x01))))    //如果RXC IRQ为1  且RXE IRQ为1 有错误发生
    PORTE&=~BIT(6);
     Delay_s(50);
     PORTE|=BIT(6);
     Delay_s(50);              //读出错误的数据
    NewData=0;                      //标志位置0
   else
    NewData=0;
        PORTE&=~BIT(5);
     Delay_s(50);
     PORTE|=BIT(5);
     Delay_s(50);
发送程序:
#include <macros.h>
#include "LpRegs.h"
unsigned char cyrf6936_send_buf[16]={0x11,0x12,0x13,0x14,0x15,
                                     0x16,0x17,0x18,0x19,0x20,
          0x21,0x22,0x23,0x24,0x25,0x26};
return;
unsigned char i;
{  delay_ms(250);
    delay_ms(250);
    delay_ms(250);
    delay_ms(250);
void spi_init(void)
   SPCR=0x50;
   SPSR = 0x00;
   SPDR = byte;
   byte = SPDR;
   SPDR = 0x00;
   return SPDR;
   addr = addr|0x80;
   CLR_SS;
   SpiWriteByte(addr);
   SpiWriteByte(data);
   SET_SS;
   CLR_SS;
   SpiWriteByte(addr);
   SET_SS;
   return buffer;
void MyRadioInit()
    SET_SS;
void PacketTX(unsigned char send_length,unsigned char send_buf[16])
unsigned char i;
//write_byte(0x0F,0x27);
write_byte(0X02,0x40);
CLR_SS;
SpiWriteByte(0x81);
SpiWriteByte(send_length);
SET_SS;
CLR_SS;
SpiWriteByte(0xA0);
for(i=0;i<send_length;i++)
     SpiWriteByte(send_buf);
SET_SS;
  write_byte(TX_CTRL_ADR, TXC_IRQ | TX_GO); // Start transmit
  while (!(read_byte(TX_IRQ_STATUS_ADR) & TXC_IRQ))
  PORTE&=~BIT(6);
     Delay_s(30);
  PORTE|=BIT(6);
  Delay_s(30);
void main (void)
  DDRB=0b11110111;
  PORTD=0xff;
  DDRD=0b11111010;
  PORTE=0xFF;
  DDRE=0b11111111;
  spi_init();
   MyRadioInit();
  while(1)
     MyRadioInit();
     PacketTX(1,cyrf6936_send_buf);
  Delay_s(50);
     PORTE&=~BIT(2);
     Delay_s(50);
     PORTE|=BIT(2);
     Delay_s(50);
现在的问题是什么都收不到啊!!!!!!!!!
 楼主| 77114810 发表于 2012-3-20 11:21 | 显示全部楼层
自己顶下
Go_PSoC 发表于 2012-3-20 22:14 | 显示全部楼层
帮你顶一下,或者你问一下support_china@cypress.com
 楼主| 77114810 发表于 2012-3-27 11:35 | 显示全部楼层
谢谢楼上的
 楼主| 77114810 发表于 2016-11-24 15:49 | 显示全部楼层
发现了自己四年前发的帖子,早就不用这个芯片了,具体什么原因也早就忘记了。刚才看了一眼,我定义了一个数组居然没有说明多大
