GD32F450 ADC始终无法采集到数据
1449|1
 楼主| Rogerzl1234 发表于 2021-11-25 15:18 | 显示全部楼层 |阅读模式
这是我写的代码,在RDATA寄存中始终没有数据传输过来,还请各位帮忙看一下,谢谢
static void ADC_GPIO_Config(void)
         rcu_periph_clock_enable(RCU_GPIOA);
         gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_3);
static void ADC_Mode_Config(void)
        rcu_periph_clock_enable(RCU_ADC0);
        adc_clock_config(ADC_ADCCK_PCLK2_DIV8);
        adc_deinit();
        adc_sync_mode_config(ADC_SYNC_MODE_INDEPENDENT);//
        adc_special_function_config(ADC0, ADC_CONTINUOUS_MODE, ENABLE);
        adc_special_function_config(ADC0, ADC_SCAN_MODE, ENABLE);
        adc_data_alignment_config(ADC0, ADC_DATAALIGN_LEFT);
        adc_resolution_config(ADC0,ADC_RESOLUTION_12B);
        adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 1);
        adc_regular_channel_config(ADC0, 1, ADC_CHANNEL_3, ADC_SAMPLETIME_112);
        adc_external_trigger_config(ADC0, ADC_REGULAR_CHANNEL, EXTERNAL_TRIGGER_DISABLE);
        adc_interrupt_enable(ADC0, ADC_INT_EOC);
        nvic_irq_enable(ADC_IRQn,0,0);
        adc_enable(ADC0);
        ADC_Delay(0xffffff);
        adc_calibration_enable(ADC0);
        ADC_Delay(0xffff);
        adc_software_trigger_enable(ADC0, ADC_REGULAR_CHANNEL);
        flag_value =  adc_regular_software_startconv_flag_get(ADC0);
void ADC_Config(void)
        ADC_GPIO_Config();
        ADC_Mode_Config();
void ADC_IRQHandler(void)
        if(adc_interrupt_flag_get(ADC0,ADC_INT_FLAG_EOC)==SET)
                adc_vaule = adc_regular_data_read(ADC0);
        adc_interrupt_flag_clear(ADC0,ADC_INT_FLAG_EOC);
void ADC_Delay(__IO uint32_t nCount)         //简单的延时函数
        for(; nCount != 0; nCount--);
sonicll 发表于 2021-11-25 15:59 | 显示全部楼层
转换序号要从0开始,不是1
