PWM捕获模式
1099|0
QQ2224043166|  楼主 | 2021-12-11 16:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
float CAPTURE_PWM_TIME_UP=0;
float CAPTURE_PWM_TIME_ALL=0;
float CAPTURE_PWM_TIME_LAST=0;
/*----------------------------- TIMER14 500hz  -----------------------------------*/
void Timer15_pwm_capture(void)
     TIMER_BaseInitPara   TIM_TimeBaseStructure;
         NVIC_InitPara        NVIC_InitStructure;
         GPIO_InitPara        GPIO_InitStructure;
         TIMER_ICInitPara     TIMER_ICInitParaStruct;
         RCC_AHBPeriphClock_Enable(RCC_AHBPERIPH_GPIOA , ENABLE);//GPIO时钟使能
         RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_CFG, ENABLE); //映射时钟
         RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_TIMER15, ENABLE);
     GPIO_InitStructure.GPIO_Pin    = GPIO_PIN_3; //输入捕获
         GPIO_InitStructure.GPIO_Mode   = GPIO_MODE_AF;
         GPIO_InitStructure.GPIO_Speed  = GPIO_SPEED_50MHZ;
     GPIO_InitStructure.GPIO_OType  = GPIO_OTYPE_PP;
         GPIO_InitStructure.GPIO_PuPd   = GPIO_PUPD_PULLDOWN;
         GPIO_Init(GPIOA, &GPIO_InitStructure);
         GPIO_PinAFConfig(GPIOA,GPIO_PINSOURCE3,GPIO_AF_0);//配置映射为 TIM15_CH2
     TIMER_DeInit(TIMER15);
     TIM_TimeBaseStructure.TIMER_Period = 30000-1;   //720-10k  2.5k
     TIM_TimeBaseStructure.TIMER_Prescaler = 1-1;
     TIM_TimeBaseStructure.TIMER_ClockDivision = TIMER_CDIV_DIV1;
     TIM_TimeBaseStructure.TIMER_CounterMode = TIMER_COUNTER_UP;//向上计数
     TIMER_BaseInit(TIMER15, &TIM_TimeBaseStructure); //使能定时器
     NVIC_InitStructure.NVIC_IRQ = TIMER15_IRQn; //中断响应优先级
         NVIC_InitStructure.NVIC_IRQPreemptPriority=0;
         NVIC_InitStructure.NVIC_IRQSubPriority = 0;
         NVIC_InitStructure.NVIC_IRQEnable = ENABLE;
         NVIC_Init(&NVIC_InitStructure);
         //这里配置了一个通道,另一个通道会自动配置
         TIMER_ICInitParaStruct.TIMER_CH          = TIMER_CH_2;//捕获通道  TIMER_CH_2
         TIMER_ICInitParaStruct.TIMER_ICPolarity  =TIMER_IC_POLARITY_RISING;//捕获极性上升沿捕获
         TIMER_ICInitParaStruct.TIMER_ICSelection =TIMER_IC_SELECTION_DIRECTTI;//映射关系
         TIMER_ICInitParaStruct.TIMER_ICPrescaler =TIMER_IC_PSC_DIV1;//分频系数
         TIMER_ICInitParaStruct.TIMER_ICFilter    =0x00;//滤波器
         **TIMER_PWMCaptureConfig(TIMER15,&TIMER_ICInitParaStruct);**//第一种是配置   TIMER_ICInit(),现在这里配置的是TIMER_PWMCaptureConfig();
         TIMER_SelectInputTrigger(TIMER15,TIMER_TS_TI2FP2);
         TIMER_SelectSlaveMode(TIMER15,TIMER_SLAVE_MODE_RESET);
         TIMER_SelectMasterSlaveMode(TIMER15,TIMER_MASTER_SLAVE_MODE_ENABLE);
         TIMER_ClearIntBitState(TIMER15, TIMER_INT_UPDATE);//清除定时器中断标志
         TIMER_ClearIntBitState(TIMER15, TIMER_INT_CH2);
         TIMER_INTConfig(TIMER15,TIMER_INT_CH2, ENABLE);//使能定时器中断
         TIMER_SetCounter(TIMER15,0x0000);//设置计数器的值
         TIMER_Enable(TIMER15, ENABLE);//使能定时器
void TIM15_IRQHandler(void)
  CAPTURE_PWM_TIME_UP = (float)(TIMER15->CHCC1);//上升沿计数值,读取捕获值会自动清空中断标志
  CAPTURE_PWM_TIME_ALL   =(float)(TIMER15->CHCC2);//总pwm计数值,读取捕获值会自动清空中断标志
