调试GD32F407xx分享(二)
1088|0
 楼主| QQ2224043166 发表于 2021-12-20 19:05 | 显示全部楼层 |阅读模式
2.2sysTick
void systick_config(void)
  /* setup systick timer for 1000Hz interrupts */
  if (SysTick_Config(SystemCoreClock / 1000U)){
      /* capture error */
      while (1){
//    /* configure the systick handler priority */
//    NVIC_SetPriority(SysTick_IRQn, 0x00U);
2.3.RTC#define RTC_CLOCK_SOURCE_LXTAL
#define BKP_VALUE    0x32F0
__IO uint32_t prescaler_a = 0, prescaler_s = 0;
typedef struct {
  unsigned short  year;
  unsigned char   mon;
  unsigned char   day;
  unsigned char   week;
  unsigned char   hour;
  unsigned char   min;
  unsigned char   sec;
}tm;
* @brief  Converts a 2 digit decimal to BCD format.
* @param  Value Byte to be converted
* @retval Converted byte
uint8_t RTC_ByteToBcd2(uint8_t Value)
  uint32_t bcdhigh = 0U;
  while(Value >= 10U)
    bcdhigh++;
    Value -= 10U;
  return  ((uint8_t)(bcdhigh << 4U) | Value);
* @brief  Converts from 2 digit BCD to Binary.
* @param  Value BCD value to be converted
* @retval Converted word
uint8_t RTC_Bcd2ToByte(uint8_t Value)
    uint32_t tmp = 0U;
    tmp = ((uint8_t)(Value & (uint8_t)0xF0) >> (uint8_t)0x4) * 10;
    return (tmp + (Value & (uint8_t)0x0F));
void rtc_setup(void)
  rtc_parameter_struct   rtc_initpara;
  /* setup RTC time value */
  rtc_initpara.factor_asyn = prescaler_a;
  rtc_initpara.factor_syn = prescaler_s;
  rtc_initpara.year = RTC_ByteToBcd2(FIRST_YEAR - 2000);
  rtc_initpara.day_of_week = RTC_SATURDAY;
  rtc_initpara.month = RTC_ByteToBcd2(FIRST_MONTH);
  rtc_initpara.date  = RTC_ByteToBcd2(FIRST_MDAY);
  rtc_initpara.display_format = RTC_24HOUR;
  rtc_initpara.am_pm = RTC_AM;
  rtc_initpara.hour   = 0x08;
  rtc_initpara.minute = 0x00;
  rtc_initpara.second = 0x00;
  /* RTC current time configuration */
  if(ERROR == rtc_init(&rtc_initpara))
  //        printf("\n\r** RTC time configuration failed! **\n\r");
  else
  //        printf("\n\r** RTC time configuration success! **\n\r");
          RTC_BKP0 = BKP_VALUE;
  //    rtc_alarm_disable(RTC_ALARM0);
void RTC_Initialize(void)
  /* enable PMU clock */
  rcu_periph_clock_enable(RCU_PMU);
  /* enable the access of the RTC registers */
  pmu_backup_write_enable();
  #if defined (RTC_CLOCK_SOURCE_IRC32K)
  rcu_osci_on(RCU_IRC32K);
  rcu_osci_stab_wait(RCU_IRC32K);
  rcu_rtc_clock_config(RCU_RTCSRC_IRC32K);
  prescaler_s = 0x13F;
  prescaler_a = 0x63;
  #elif defined (RTC_CLOCK_SOURCE_LXTAL)
  rcu_osci_on(RCU_LXTAL);
  rcu_osci_stab_wait(RCU_LXTAL);
  rcu_rtc_clock_config(RCU_RTCSRC_LXTAL);
  prescaler_s = 0xFF;
  prescaler_a = 0x7F;
  #else
  #error RTC clock source should be defined.
  #endif /* RTC_CLOCK_SOURCE_IRC32K */
  rcu_periph_clock_enable(RCU_RTC);
  rtc_register_sync_wait();
  /* check if RTC has aready been configured */
  if (BKP_VALUE != RTC_BKP0)
    rtc_setup();
  else
    /* detect the reset source */
    if (RESET != rcu_flag_get(RCU_FLAG_PORRST)){
  //            printf("power on reset occurred....\n\r");
    }else if (RESET != rcu_flag_get(RCU_FLAG_EPRST)){
  //            printf("external reset occurred....\n\r");
  //        printf("no need to configure RTC....\n\r");
  rcu_all_reset_flag_clear();
  RTC_Get(&rtc_timer);
void RTC_Get(tm* t)
//    uint32_t time_subsecond = 0;
  rtc_current_time_get(&rtc_initpara);
  /* get the subsecond value of current time, and convert it into fractional format */
//    time_subsecond = rtc_subsecond_get();
  t->year = RTC_Bcd2ToByte(rtc_initpara.year) + 2000;
  t->mon  = RTC_Bcd2ToByte(rtc_initpara.month);
  t->day  = RTC_Bcd2ToByte(rtc_initpara.date);
  t->hour = RTC_Bcd2ToByte(rtc_initpara.hour);
  t->min  = RTC_Bcd2ToByte(rtc_initpara.minute);
  t->sec  = RTC_Bcd2ToByte(rtc_initpara.second);
void RTC_Set( tm* t )
  rtc_initpara.year = RTC_ByteToBcd2(t->year - 2000);
  rtc_initpara.day_of_week = RTC_ByteToBcd2(t->week);
  rtc_initpara.month = RTC_ByteToBcd2(t->mon);
  rtc_initpara.date  = RTC_ByteToBcd2(t->day);
  rtc_initpara.hour   = RTC_ByteToBcd2(t->hour);
  rtc_initpara.am_pm  = (t->hour < 12) ? RTC_AM : RTC_PM;
  rtc_initpara.minute = RTC_ByteToBcd2(t->min);
  rtc_initpara.second = RTC_ByteToBcd2(t->sec);
  else
