[DemoCode下载] [NUC131] Transferring CAN Message Periodically
731|0
 楼主| 奔跑的牛 发表于 2021-12-23 17:48 | 显示全部楼层 |阅读模式
AN, Appli, IO, TI, ge
  • Application: This sample code uses NUC131SD2AEU to transfer CAN messages periodically and debug CAN interface.
  • BSP Version: NUC131 BSP CMSIS V3.00.005
  • Hardware: NuMaker-NUC131U V1.0
When configuring four messages, two messages of them will be updated every 2 seconds and the other two messages will not be updated. Only one of the four messages will be transferred actively every 2 seconds and the other three messages always wait for a remote frame.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1124135846
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
