GD32E230C8 RTC 使用外部晶振不走时,要怎么配置呢?
1277|2
lang30|  楼主 | 2021-12-28 00:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
换成IRC40K 就能走时;还需要配置哪里呢?
<div class="blockcode"><blockquote>// #define RTC_CLOCK_SOURCE_IRC40K
#define RTC_CLOCK_SOURCE_LXTAL
void rtc_pre_config(void)
    /* enable access to RTC registers in backup domain */
    rcu_periph_clock_enable(RCU_PMU);
    pmu_backup_write_enable();
    #if defined (RTC_CLOCK_SOURCE_IRC40K)
          /* enable the IRC40K oscillator */
          rcu_osci_on(RCU_IRC40K);
          /* wait till IRC40K is ready */
          rcu_osci_stab_wait(RCU_IRC40K);
          /* select the RTC clock source */
          rcu_rtc_clock_config(RCU_RTCSRC_IRC40K);
          prescaler_s = 0x18F;
          prescaler_a = 0x63;
    #elif defined (RTC_CLOCK_SOURCE_LXTAL)
          rcu_osci_on(RCU_LXTAL);
          rcu_osci_stab_wait(RCU_LXTAL);
          rcu_rtc_clock_config(RCU_LXTAL);
          prescaler_s = 0xFF;
          prescaler_a = 0x7F;
    #else
    #error RTC clock source should be defined.
    #endif /* RTC_CLOCK_SOURCE_IRC40K */
    rcu_periph_clock_enable(RCU_RTC);
    rtc_register_sync_wait();
QQ2224043166| | 2021-12-31 09:41 | 只看该作者
void RTC_Set( tm* t )
  rtc_parameter_struct   rtc_initpara;
  /* setup RTC time value */
  rtc_initpara.factor_asyn = prescaler_a;
  rtc_initpara.factor_syn  = prescaler_s;
  rtc_initpara.year = RTC_ByteToBcd2(t->year - 2000);
  rtc_initpara.day_of_week = RTC_ByteToBcd2(t->week);
  rtc_initpara.month = RTC_ByteToBcd2(t->mon);
  rtc_initpara.date  = RTC_ByteToBcd2(t->day);
  rtc_initpara.display_format = RTC_24HOUR;
  rtc_initpara.hour   = RTC_ByteToBcd2(t->hour);
  rtc_initpara.am_pm  = (t->hour < 12) ? RTC_AM : RTC_PM;
  rtc_initpara.minute = RTC_ByteToBcd2(t->min);
  rtc_initpara.second = RTC_ByteToBcd2(t->sec);
  /* RTC current time configuration */
  if(ERROR == rtc_init(&rtc_initpara))
//        printf("\n\r** RTC time configuration failed! **\n\r");
  else
//        printf("\n\r** RTC time configuration success! **\n\r");
      RTC_BKP0 = BKP_VALUE;
lang30|  楼主 | 2022-1-6 11:41 | 只看该作者
这个只是设置时间, 不是配置啊
