[DemoCode下载] [M480] Reading RFID Card by SPI Interface
891|0
 楼主| 奔跑的牛 发表于 2021-12-28 15:49 | 显示全部楼层 |阅读模式
  • Application: This example code uses M480 SPI to communicate with the MFRC522 module to read the Unique Identification (UID) of RFID card.
  • BSP Version: M480 BSP CMSIS V3.03.000
  • Hardware: NuMaker-PFM-M487 V3.0, MFRC522 module, RFID card
This example code uses the M480 series microcontroller as the host controller to communicate with the MFRC522 module to read the UID of RFID card. The MFRC522 is one of NXP MIFARE series chips. It supports all variants of the MIFARE identification protocols. The MFRC522 is a highly integrated reader/writer IC for contactless communication at 13.56 MHz, and its internal transmitter is able to drive a reader/writer antenna designed to communicate with ISO/IEC 14443 Type A cards and transponders without additional active circuitry.
From the definition in ISO/IEC 14443, the MFRC522 and RFID card work as the Proximity Coupling Device (PCD) and Proximity Card (PICC), respectively. The communication protocol between PCD and PICC must be compliant with ISO/IEC 14443.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1129132546
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
