[技术问答] 使用ML51EB9AE开发板,借用库函数开发,用定时器产生PWM波,以下代码有啥逻辑问题吗
937|1
 楼主| 爱电子的小枫 发表于 2022-1-4 15:59 | 显示全部楼层 |阅读模式
#include "ML51.h"
/* if define TIMER0_FSYS_DIV12, timer = (0x1FFF-0x1000)*12/24MHz = 4.08ms */
/* if define TIMER0_FSYS, timer = (0x1FFF-0x0010)/24MHz = 340us */
#define TH0_INIT        0x10
#define TL0_INIT        0x00
#define pwm_num 1000
sbit LED = P1^4;
*    TIMER 0 interrupt subroutine
void Timer0_ISR (void) interrupt 1           //interrupt address is 0x000B
          static unsigned char counter = 0;
    _push_(SFRS);
    TH0 = TH0_INIT;
    TL0 = TL0_INIT;
    TF0 = 0 ;
    P32 = ~P32;                              // GPIO toggle when interrupt
          counter++;
          if(counter==1500)
                        counter=0;
                LED = (counter<=pwm_num)?0:1;
    _pop_(SFRS);
*    Main function
void main (void)
        /* As defaut all multi function define as GPIO */
    ALL_GPIO_QUASI_MODE;
    MFP_P32_GPIO;
    P32_PUSHPULL_MODE;
          MFP_P14_GPIO;
    P14_PUSHPULL_MODE;
    ENABLE_TIMER1_MODE0;                        //Timer 0 mode configuration
    TIMER0_FSYS_DIV12;
    TH0 = TH0_INIT;
    TL0 = TL0_INIT;
    ENABLE_TIMER0_INTERRUPT;                    //enable Timer0 interrupt
    ENABLE_GLOBAL_INTERRUPT;                    //enable interrupts
    set_TCON_TR0;                               //Timer0 run
    while(1);
单片小菜 发表于 2022-1-5 10:32 | 显示全部楼层
现在遇到什么问题呢?说一下看看。
