[DemoCode下载] [NUC131] Using CAN to Adjusting Baud Rate Automatically
678|1
 楼主| 奔跑的牛 发表于 2022-1-13 14:11 | 显示全部楼层 |阅读模式
  • Application: This sample code receives data on the CAN bus by periodically changing the baud rate of NUC131 CAN to match the baud rate of the CAN bus.
  • BSP Version: NUC131 Series BSP CMSIS V3.00.005
  • Hardware: NuTiny-EVB-NUC131-LQFP64 V1.0
This sample code contains two projects, "CAN_TX_RX" and "CAN_Auto_Adjust_BPS". The "CAN_TX_RX" is a CAN sending and receiving demo, which is written to facilitate testing the function of "CAN_Auto_Adjust_BPS" demo.
The "CAN_Auto_Adjust_BPS" demo receives data on the CAN bus by periodically changing the baud rate of NUC131 CAN until it can normally receive data on the CAN bus, so as to match the baud rate of the CAN bus. After matching the baud rate of the CAN bus, packets will be periodically sent to the CAN bus. This demo can detect whether the baud rate range is 50 Kbps~1 Mbps, and step is 50 Kbps.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0908174604
豌豆爹 发表于 2022-1-18 09:03 来自手机 | 显示全部楼层
楼主能在发一遍翻译过来的版本吗
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
