[DemoCode下载] [ML56] Using Touch Slider to Control ARGB LED
739|0
 楼主| 奔跑的牛 发表于 2022-1-17 15:02 | 显示全部楼层 |阅读模式
  • Application: This sample code uses touch slider to control ARGB LED effect and uses SPI to simulate ARGB LED timing sequence on ML56 series.
  • BSP Version: ML51 Series BSP V2.00.001
  • Hardware: ML56 Demo Board Ver1.0
This sample code uses touch slider to control ARGB to do LED dimming and uses SPI to simulate ARGB LED timing sequence to achieve intuitive brightness control.
The ML56 demo board is a sensing board with a slider and a wheel. All of the sensors on this board are capacitive touch key sensing. The 6-element slider is connected to the following I/O: TK2(P29), TK3(P28), TK4(P27), TK5(P26), TK6(P25) and TK7(P24). When the finger touches the copper pad on the PCB, the current position can be reported by detecting the measurement of the capacitance changes.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0909094711
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
