[STM32L4]
采集电池电压不准
3219|54
supernan|  楼主 | 2022-2-2 23:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
stm32l471
supernan|  楼主 | 2022-2-2 23:07 | 只看该作者
你得上程序啊
supernan|  楼主 | 2022-2-2 23:10 | 只看该作者
static void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig;
    /**Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.ContinuousConvMode = DISABLE;
  hadc1.Init.NbrOfConversion = 1;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.NbrOfDiscConversion = 1;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  hadc1.Init.OversamplingMode = DISABLE;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
    /**Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_VBAT;  //ADC_CHANNEL_TEMPSENSOR  ADC_CHANNEL_VBAT ADC_CHANNEL_VREFINT
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_2CYCLES_5;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
float GetVbat11(void)
        volatile uint32_t ad;
        float v;
        HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED);
        MyDelay(10000);
        HAL_ADC_Start(&hadc1);
        MyDelay(10000);
        ad = HAL_ADC_GetValue(&hadc1);
        MyDelay(10000);
        //HAL_Delay(10);
        HAL_ADC_Stop(&hadc1);
        v = ad / 4096.0 * 3 * 3 * 1000;
        return v;
jlyuan| | 2022-2-2 23:13 | 只看该作者
还有什么现象?能再详细描述下吗?
supernan|  楼主 | 2022-2-2 23:17 | 只看该作者
采集出来的电压值 和实际不符,我电池电压在3.5的时候,输出才有3.15左右   看手册 看了好几遍了   也没看出哪里还有问题
dingy| | 2022-2-2 23:18 | 只看该作者
采集实际电压之前不妨先给改ADC输入管脚输入一个0V和3.3V,看看单片机采集出来的电压是否与实际电压相等
supernan|  楼主 | 2022-2-2 23:21 | 只看该作者
ADC有个电压校准接口,可以尝试一下
lizye| | 2022-2-2 23:23 | 只看该作者
再者,采集电压3.5V如果直接接到单片机,应该是不行的。
supernan|  楼主 | 2022-2-2 23:26 | 只看该作者
来点人 指导下  这手册看的都快吐了     测refint通道测出来的值和内部存储器57aa地址的值 也有差距
chuxh| | 2022-2-2 23:27 | 只看该作者
你芯片的vdda是多少?
dingy| | 2022-2-2 23:29 | 只看该作者
待测信号电压不得高于VDDA,而VDDA又不高于3.6V.
chuxh| | 2022-2-2 23:35 | 只看该作者
如果你外接VREF,它不得高于VDDA。
dingy| | 2022-2-2 23:37 | 只看该作者
另外,你把采样时间适当调长点。
huangchui| | 2022-2-2 23:39 | 只看该作者
是不是输入阻抗的问题
supernan|  楼主 | 2022-2-2 23:41 | 只看该作者
片子电源VDDA为3.0v    vabt为 3.5v  vref接vdda 为3.0v      试过延时 时间长 也是一样
supernan|  楼主 | 2022-2-2 23:43 | 只看该作者
这个就是电池的正极直接接单片机vbat引脚 ,应该是输入阻抗在20mΩ以下
spark周| | 2022-2-2 23:46 | 只看该作者
参考电压准吗,采集时间够吗
renyaq| | 2022-2-2 23:48 | 只看该作者
你测试vbat电压,这个电压高于vdda,不行。
yszong| | 2022-2-2 23:50 | 只看该作者
跟硬件电路也有关系
yinxiangh| | 2022-2-2 23:52 | 只看该作者
被采样的频率是多少啊
