[技术问答]
Use CAN in RTX
708|9
jcky001|  楼主 | 2022-3-2 09:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AN, se
  • Application: This code demos CAN interface in RTX.
  • BSP Version: M480 Series BSP CMSIS V3.03.000
  • Hardware: NuMaker-ETM-M487 v1.2
When a microcontroller application has to handle many tasks at the same time, we can use RTOS (real-time operating system) to help us manage these tasks. In RTOS system, CPU processing time is divided into a number of time slots. Each time slot processes different task and the switching between these tasks can be hundred times per second. It means that the application tasks are running simultaneously. When the application becomes more complicated, we can use RTOS to help us manage these tasks.
CMSIS-RTOS in Keil MDK (Microcontroller Development Kit) provides a standard API for RTOS and application layer, includes the Keil free RTOS, RTX (Real-Time eXecutive) kernel. Once others RTOS can support CMSIS-RTOS, we can also port our application to others RTOS platform easily. This sample code uses RTX kernel, which is provided by Keil CMSIS-MDK, to create a RTX kernel system to execute CAN task.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1217164453
sparrow054| | 2022-3-3 13:14 | 只看该作者
上这一大段是啥
内政奇才| | 2022-3-3 16:31 | 只看该作者
实在不懂可以用金山词霸翻译一下
sparrow054| | 2022-3-7 13:41 | 只看该作者
内政奇才 发表于 2022-3-3 16:31
实在不懂可以用金山词霸翻译一下
你是高手
tpgf| | 2022-4-1 10:40 | 只看该作者
我没看明白啥意思啊
heimaojingzhang| | 2022-4-1 10:47 | 只看该作者
can用在接收数据端吗
keaibukelian| | 2022-4-1 10:54 | 只看该作者
还是下载代码看看吧
labasi| | 2022-4-1 11:13 | 只看该作者
其实仔细看不那么难
paotangsan| | 2022-4-1 11:20 | 只看该作者
介绍了一段代码的功能
renzheshengui| | 2022-4-1 11:26 | 只看该作者
还是读一下代码内容吧
