[N32G45x]
n32g457在rtt中使用us函数造成程序卡死
486|0
18785275440|  楼主 | 2022-3-10 13:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是us延时函数
void delay_us(rt_uint32_t nus)
        u32 temp;
        SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);    //select system clock
        SysTick->LOAD=nus*(SystemCoreClock/(1000000/RT_TICK_PER_SECOND)); //time relode
        SysTick->VAL=0x00;        //clear timer value
        SysTick->CTRL|=SysTick_CTRL_ENABLE_Msk ;  //Start countdown
        do
            temp=SysTick->CTRL;
        while(temp&0x01&&!(temp&(1<<16)));//wait for the time reach
        SysTick->CTRL&=~SysTick_CTRL_ENABLE_Msk;       //close the count
        SysTick->VAL =0X00;       //clear timer value
msh >[W/UART] Warning: There is no enough buffer for saving data, please increase the RT_SERIAL_RB_BUFSZ option.
list_thread
thread   pri  status      sp     stack size max used left tick  error
serial3    9  suspend 0x000000a4 0x00000400    16%   0x0000000a 000
serial     9  suspend 0x000000b4 0x00000400    17%   0x0000000a 000
motor      9  suspend 0x000000ac 0x00000200    33%   0x0000000a 000
key        9  suspend 0x000000b4 0x00000200    35%   0x0000000a 000
read_adc  15  suspend 0x000000bc 0x00000200    46%   0x0000000a 000
tshell    20  running 0x000000cc 0x00001000    14%   0x0000000a 000
tidle0    31  ready   0x00000074 0x00000100    45%   0x00000020 000
timer      4  suspend 0x0000007c 0x00000200    24%   0x00000009 000
main      10  suspend 0x000000b8 0x00000800    17%   0x00000007 000
msh >
