[STM32F4] STM32F407使用485程序会使flash 进行写保护
390|0
 楼主| 张年智 发表于 2022-4-11 17:27 | 显示全部楼层 |阅读模式
STM32F407使用485程序会使flash 进行写保护  而且没有监控到数发出
#include "sys.h"
#include "delay.h"
void Send_Data(u8 *buf,u8 len, USART_TypeDef* USARTx)
                uint16_t t;
          for(t=0;t<len;t++)                //循环发送数据
          while(USART_GetFlagStatus(USARTx,USART_FLAG_TC)==RESET); //等待发送结束
    USART_SendData(USART1, buf[t]); //发送数据
u8 A[]="adsadadsa";
int main(void)
        USART_InitTypeDef USART_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); //使能GPIOB时钟
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE); //使能GPIOE时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);//使能USART1时钟
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource6, GPIO_AF_USART1); //GPIO6复用为USART1
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource7, GPIO_AF_USART1); //GPIO7复用为USART1
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 ;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //速度100MHz
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        USART_InitStructure.USART_BaudRate = 115200;//波特率设置
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
        USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
        USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收发模式
        USART_Init(USART1, &USART_InitStructure); //初始化串口
        USART_Cmd(USART1, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;//GPIOG8
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//输出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;        //速度100MHz
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽输出
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //上拉
        GPIO_Init(GPIOE,&GPIO_InitStructure);
        GPIO_SetBits(GPIOE, GPIO_Pin_12);
        while(1)
        Send_Data(A, 8, USART1);
