- void qsort(void *base, size_t nitems, size_t size, int (*compar)(const void *, const void*))
base - 指针,数组的第一个元素进行排序
nitems - 数组中的元素数目
size - 数组中的每个元素的大小(以字节为单位)
compar - 基于这个函数比较两个元素
返回值:不返回任何值
缺点:对于有多个重复值的数组来说,效率较低不稳定
范例
- //qsort要结合compare使用
- int compare(const void *value1, const void *value2)
- //升序或降序在此调整
- return (*(int*)value1 - *(int*)value2);
- int main(void)
- int data[ARRAY_SIZE] = {3, 44, 38, 5, 47, 15, 36, 26, 27, 2, 46, 4, 19, 50, 48};
- log("source", data, ARRAY_SIZE);
- qsort(data, ARRAY_SIZE, sizeof(int), compare);
- log("sort ", data, ARRAY_SIZE);
- return 0;
其效果和前面三种算法一样,而且可扩展针对结构体内某个元素值对整体排序,满足前面的wifi信息按信号强度排序的需求。
- #include <stdio.h>
- #define WIFI_AP_MAX 5
- typedef unsigned char uint8_t;
- typedef signed char int8_t;
- typedef unsigned short uint16_t;
- typedef signed short int16_t;
- typedef unsigned int uint32_t;
- typedef struct
- uint32_t bssid_low; // mac address low
- uint16_t bssid_high; // mac address high
- uint8_t channel; // channel id
- int8_t rssi; // signal strength <sort>
- } wifiApInfo_t;
- //qsort要结合compare使用,按信号强度rssi升序排列
- const wifiApInfo_t *ctx1 = (const wifiApInfo_t *)value1;
- const wifiApInfo_t *ctx2 = (const wifiApInfo_t *)value2;
- return (ctx1->rssi - ctx2->rssi);
- static wifiApInfo_t wifiApInfo[WIFI_AP_MAX] =
- {0x5555, 0x55, 5, -55},
- {0x1111, 0x11, 1, -51},
- {0x3333, 0x33, 3, -53},
- {0x4444, 0x44, 4, -54},
- {0x2222, 0x22, 2, -52},
- void wifi_log(char *head, void *data, int size)
- unsigned char i;
- const wifiApInfo_t *wifi = (wifiApInfo_t *)data;
- printf("%s:\r\n", head);
- for(i = 0; i < size; i++)
- printf("%X %X %d [%d] \r\n", wifi[i].bssid_low, wifi[i].bssid_high, wifi[i].channel, wifi[i].rssi);
- printf("\r\n\r\n");
- int main(void)
- wifi_log("source", wifiApInfo, WIFI_AP_MAX);
- qsort(wifiApInfo, WIFI_AP_MAX, sizeof(wifiApInfo_t), compare);
- wifi_log("sort", wifiApInfo, WIFI_AP_MAX);
- return 0;
- 运行结果
- source:
- 5555 55 5 [-55]
- 1111 11 1 [-51]
- 3333 33 3 [-53]
- 4444 44 4 [-54]
- 2222 22 2 [-52]
- //依据信号强度关键字,对wifi信息整体数据同步进行了排序
- sort:
- 5555 55 5 [-55]
- 4444 44 4 [-54]
- 3333 33 3 [-53]
- 2222 22 2 [-52]
- 1111 11 1 [-51]
