[PCB] wifi6 IPQ6018/IPQ6010 5G-celluar-Modem 802.11ax QCN9074 WiFi 6E Card-wallys
1278|0
 楼主| wirelesswifi6 发表于 2022-5-6 13:41 | 显示全部楼层 |阅读模式
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48
    V
    Operating Temperature Range
    -40 to +70
    ºC
    Storage Temperature Range
    -45 to +105
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
    SFP Port1x SFP port
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
    SD Card Slot
    1x SD Card Slot
    USB /header
    1x USB 2.0 Port
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V power supply
    LED header
    FFC/FPC Connector
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    BluetoothCSR8811 BLE 4.2
    Nor Flash
    32MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension
    185mm x 116mm
    Boot Config Switch
    Boot_Config Switch1(S7)
    Boot_Config
    Boot up InterfaceSelect
    S7A
    S7B
    S7C
    SPI NOR. (Default)
    eMMC
    QPIC, Parallel NAND
    USB2.0
    SPI-NOR-GPT
    S7D
    Boot from code ram.(Default)
    Boot from ROM
    Boot_Config Switch2(S9)
    Boot_Config
    No auth.(Default)
    Auth is required
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
    EMAIL:sales@wallystech.com
