[技术问答] ADC转换电压输出不稳,导致电压显示LED灯在某个电压点闪...
1013|1
 楼主| powerantone 发表于 2022-5-10 09:25 | 显示全部楼层 |阅读模式
ADC转换电压输出不稳,导致电压显示LED灯在某个电压点闪烁。
 楼主| powerantone 发表于 2022-5-10 09:26 | 显示全部楼层
问题补充 :
while(1)
                 if (time_10ms)
                 {ADCCON1|=0X30;            /* clock divider */
      ADCCON2|=0X0E;            /* AQT time */
      AUXR1|=SET_BIT4;          /* ADC clock low speed */
      clr_ADCCON0_ADCF;
      set_ADCCON0_ADCS;
       LowBat_V = (ADCRH<<4)+(ADCRL&0x0F);
        if (LowBat_V>=1280+40) //1320=3.5V       43.33=0.1V  1025/1280
        //Led_Mode=1;
        //P10=0;
        P11=1;
                                                        else if (1140<LowBat_V<1280) //1320=3.5V       43.33=0.1V
        //Led_Mode=3;
        //P10=1;
        P11=0;
