[DemoCode下载]
M031通过BSP库函数操作实现PWM触发ADC采样
885|6
小明的同学|  楼主 | 2022-5-14 21:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate how to trigger ADC by PWM.
* SPDX-License-Identifier: Apache-2.0
* [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2018 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
/* Define global variables and constants        */
volatile uint32_t g_u32AdcIntFlag, g_u32COVNUMFlag = 0;
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Set both PCLK0 and PCLK1 as HCLK/2 */
    CLK->PCLKDIV = (CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2);
    /* Switch UART0 clock source to HIRC */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Enable UART peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable PWM0 module clock */
    CLK_EnableModuleClock(PWM0_MODULE);
    /* Select PWM0 module clock source as PCLK0 */
    CLK_SetModuleClock(PWM0_MODULE, CLK_CLKSEL2_PWM0SEL_PCLK0, 0);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* ADC clock source is PCLK1, set divider to 1 */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL2_ADCSEL_PCLK1, CLK_CLKDIV0_ADC(1));
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function                                              */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk)) |
                    (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Set PB.2 - PB.3 to input mode */
    GPIO_SetMode(PB, BIT2|BIT3, GPIO_MODE_INPUT);
    /* Configure the PB.2 - PB.3 ADC analog input pins.  */
    SYS->GPB_MFPL = (SYS->GPB_MFPL & ~(SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk)) |
                    (SYS_GPB_MFPL_PB2MFP_ADC0_CH2 | SYS_GPB_MFPL_PB3MFP_ADC0_CH3);
    /* Disable the PB.2 - PB.3 digital input path to avoid the leakage current. */
    GPIO_DISABLE_DIGITAL_PATH(PB, BIT2|BIT3);
    /* Set PA multi-function pins for PWM0 Channel 0 */
    SYS->GPA_MFPL = (SYS->GPA_MFPL & (~SYS_GPA_MFPL_PA0MFP_Msk)) |
                    (SYS_GPA_MFPL_PA5MFP_PWM0_CH0);
    /* Lock protected registers */
    SYS_LockReg();
void PWM0_Init()
    /* Set PWM0 timer clock prescaler */
    PWM_SET_PRESCALER(PWM0, 0, 10);
    /* Set up counter type */
    PWM0->CTL1 &= ~PWM_CTL1_CNTTYPE0_Msk;
    /* Set PWM0 timer duty */
    PWM_SET_CMR(PWM0, 0, 1000);
    /* Set PWM0 timer period */
    PWM_SET_CNR(PWM0, 0, 2000);
    /* PWM period point trigger ADC enable */
    PWM_EnableADCTrigger(PWM0, 0, PWM_TRIGGER_ADC_EVEN_PERIOD_POINT);
    /* Set output level at zero, compare up, period(center) and compare down of specified channel */
    PWM_SET_OUTPUT_LEVEL(PWM0, BIT0, PWM_OUTPUT_HIGH, PWM_OUTPUT_LOW, PWM_OUTPUT_NOTHING, PWM_OUTPUT_NOTHING);
    /* Enable output of PWM0 channel 0 */
    PWM_EnableOutput(PWM0, BIT0);
void ADC_FunctionTest()
    uint8_t  u8Option;
    int32_t  i32ConversionData[6] = {0};
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                      ADC trigger by PWM test                         |\n");
    printf("\nIn this test, software will get 6 conversion result from the specified channel.\n");
    /* Enable ADC converter */
    ADC_POWER_ON(ADC);
    while(1)
        printf("Select input mode:\n");
        printf("  [1] Single end input (channel 2 only)\n");
        printf("  [2] Differential input (channel pair 1 only)\n");
        printf("  Other keys: exit single mode test\n");
        u8Option = getchar();
        if(u8Option == '1')
            /* Set input mode as single-end, Single mode, and select channel 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE, BIT2);
            /* Configure the sample module and enable PWM0 trigger source */
            ADC_EnableHWTrigger(ADC, ADC_ADCR_TRGS_PWM, 0);
            /* Clear the A/D interrupt flag for safe */
            ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
            /* Enable the sample module interrupt */
            ADC_ENABLE_INT(ADC, ADC_ADF_INT);  /* Enable sample module A/D interrupt. */
            NVIC_EnableIRQ(ADC_IRQn);
            printf("Conversion result of channel 2:\n");
            /* Reset the ADC indicator and enable PWM0 channel 0 counter */
            g_u32AdcIntFlag = 0;
            PWM_Start(PWM0, PWM_CH_0_MASK); /* PWM0 channel 0 counter start running. */
            while(1)
                /* Wait ADC interrupt (g_u32AdcIntFlag will be set at IRQ_Handler function) */
                while(g_u32AdcIntFlag == 0);
                /* Reset the ADC interrupt indicator */
                /* Get the conversion result of the ADC channel 2 */
                i32ConversionData[g_u32COVNUMFlag - 1] = ADC_GET_CONVERSION_DATA(ADC, 2);
                if(g_u32COVNUMFlag >= 6)
                    break;
            /* Disable PWM0 channel 0 counter */
            PWM_ForceStop(PWM0, BIT0);  /* PWM0 counter stop running. */
            for(g_u32COVNUMFlag = 0; (g_u32COVNUMFlag) < 6; g_u32COVNUMFlag++)
                printf("                                0x%X (%d)\n", i32ConversionData[g_u32COVNUMFlag], i32ConversionData[g_u32COVNUMFlag]);
        else if(u8Option == '2')
            /* Set input mode as differential, Single mode, and select channel 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_SINGLE, BIT2);
            while(1)
                    break;
        else
            return ;
void ADC_IRQHandler(void)
    ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT); /* Clear the A/D interrupt flag */
    g_u32AdcIntFlag = 1;
    g_u32COVNUMFlag++;
/* Init UART0                                                           */
void UART0_Init(void)
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
int32_t main(void)
    /* Init System, IP clock and multi-function I/O. */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init PWM for ADC */
    PWM0_Init();
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    /* ADC function test */
    ADC_FunctionTest();
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable PWM0 IP clock */
    CLK_DisableModuleClock(PWM0_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("Exit ADC sample code\n");
    while(1);
小明的同学|  楼主 | 2022-5-14 21:17 | 只看该作者
现代人更喜欢这个操作,是吧
koala889| | 2022-5-15 07:55 | 只看该作者
现在越来越多的喜欢PWM了
小明的同学|  楼主 | 2022-5-28 11:57 | 只看该作者
koala889 发表于 2022-5-15 07:55
现在越来越多的喜欢PWM了
主要是这个外设用处多。
koala889| | 2022-6-3 08:21 | 只看该作者
小明的同学 发表于 2022-5-28 11:57
主要是这个外设用处多。
是啊,用处太多了
andygirl| | 2022-6-10 22:33 | 只看该作者
为什么要用pwm触发ADC
skyred| | 2022-6-11 21:10 | 只看该作者
这和周期性采样,有何不同
