[技术问答] M487JIDAE和IP101GR芯片,连接以太网成功一段时间就不行了,求助各位!!!!!!!!!!!
868|8
 楼主| fst20220608 发表于 2022-6-9 14:17 | 显示全部楼层 |阅读模式
我使用官方给的例程EMAC_TxRx和EC_M480_Ethernet_USBH_Bridge_V1.00这个例程,插入网线刚开始都能正常,过了一段时间,以太网没网了,在电脑上ping ip 也不行,以下是例程EMAC_TxRx代码:
// Our MAC address
uint8_t g_au8MacAddr[6] = {0x00, 0x00, 0x00, 0x59, 0x16, 0x88};
// Our IP address
uint8_t volatile g_au8IpAddr[4] = {0, 0, 0, 0};
uint8_t auPkt[1514];
uint32_t u32PktLen;
// Descriptor pointers holds current Tx and Rx used by IRQ handler here.
uint32_t u32CurrentTxDesc, u32CurrentRxDesc;
void TMR0_IRQHandler(void)
//    static unsigned char count = 0;
    //printf("%d sec\n", sec++);
    // clear timer interrupt flag
    TIMER_ClearIntFlag(TIMER0);
    PH0=!PH0;
    PH1=!PH1;
    PH2=!PH2;
    printf("1s enter TIM interrupt\r\n");
//    __NOP();
  * @brief  EMAC Tx interrupt handler.
  * @param  None
  * @return None
void EMAC_TX_IRQHandler(void)
    // Clean up Tx resource occupied by previous sent packet(s)
    EMAC_SendPktDone();
  * @brief  EMAC Rx interrupt handler.
  * @param  None
  * @return None
void EMAC_RX_IRQHandler(void)
    int i=0;
//    while(1)
        printf("u32PktLen =%d\r\n",u32PktLen);
        // Check if there's any packets available
        if(EMAC_RecvPkt(auPkt, &u32PktLen) == 0)
            return;
            //break;
        // Process receive packet
        process_rx_packet(auPkt, u32PktLen);
        for(i=0;i<u32PktLen;i++)
            if(auPkt==192)
                printf("IP address: %d.%d.%d.%d\n", auPkt, auPkt[i+1],auPkt[i+2], auPkt[i+3]);
        // Clean up Rx resource occupied by previous received packet
        EMAC_RecvPktDone();
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
    PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
    /* Enable External XTAL (4~24 MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for 12MHz clock ready */
    CLK_WaitClockReady( CLK_STATUS_HXTSTB_Msk);
    /* Switch HCLK clock source to HXT */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HXT,CLK_CLKDIV0_HCLK(1));
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(FREQ_192MHZ);
    /* Set both PCLK0 and PCLK1 as HCLK/2 */
    CLK->PCLKDIV = CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2;
    /* Enable IP clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(EMAC_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
    // Configure MDC clock rate to HCLK / (127 + 1) = 1.5 MHz if system is running at 192 MHz
    CLK_SetModuleClock(EMAC_MODULE, 0, CLK_CLKDIV3_EMAC(127));
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
    SystemCoreClockUpdate();
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFPH &= ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
    SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    // Configure RMII pins
    SYS->GPA_MFPL |= SYS_GPA_MFPL_PA6MFP_EMAC_RMII_RXERR | SYS_GPA_MFPL_PA7MFP_EMAC_RMII_CRSDV;
    SYS->GPC_MFPL |= SYS_GPC_MFPL_PC6MFP_EMAC_RMII_RXD1 | SYS_GPC_MFPL_PC7MFP_EMAC_RMII_RXD0;
    SYS->GPC_MFPH |= SYS_GPC_MFPH_PC8MFP_EMAC_RMII_REFCLK;
    SYS->GPE_MFPH |= SYS_GPE_MFPH_PE8MFP_EMAC_RMII_MDC |
                     SYS_GPE_MFPH_PE9MFP_EMAC_RMII_MDIO |
                     SYS_GPE_MFPH_PE10MFP_EMAC_RMII_TXD0 |
                     SYS_GPE_MFPH_PE11MFP_EMAC_RMII_TXD1 |
                     SYS_GPE_MFPH_PE12MFP_EMAC_RMII_TXEN;
    // Enable high slew rate on all RMII TX output pins
    PE->SLEWCTL = (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN10_Pos) |
                  (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN11_Pos) |
                  (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN12_Pos);
    /* Lock protected registers */
    SYS_LockReg();
// This sample application can response to ICMP ECHO packets (ping)
// IP address is configure with DHCP, but if a lease cannot be acquired, a static IP will be used.
int main(void)
    SYS_Init();
    UART_Open(UART0, 115200);
    Led_init();
    key_init();
    TIM_init();
    // Select RMII interface by default
    EMAC_Open(g_au8MacAddr);
    // Init phy
    EMAC_PhyInit();
    NVIC_EnableIRQ(EMAC_TX_IRQn);
    NVIC_EnableIRQ(EMAC_RX_IRQn);
    EMAC_ENABLE_RX();
    EMAC_ENABLE_TX();
    printf("emaec enable rx dfksa \r\n");
    if (dhcp_start() < 0)
        // Cannot get a DHCP lease, use static IP.
        printf("DHCP failed, use static IP 192.168.10.10\n");
        g_au8IpAddr[0] = 0xC0;
        g_au8IpAddr[1] = 0xA8;
        g_au8IpAddr[2] = 0x0A;
        g_au8IpAddr[3] = 0x0A;
这是原理图:
    while(1);
zhuotuzi 发表于 2022-6-9 20:15 | 显示全部楼层
代码这么贴不容易看,建议跌到代码专用框里。
caoqing 发表于 2022-6-9 21:53 | 显示全部楼层
改为固定IP试试
caoqing 发表于 2022-6-9 21:56 | 显示全部楼层
该程序使用了中断的方式接收网卡数据包,在每次中断中只读取网卡的一个数据包。如果一次中断发生,而网卡内事实上可能存在有多个数据包,这样如果只读一个,最终导致网卡内数据包积压,所以会出现ping延迟的现象。如果数据包长期积压,还可能出现因网卡缓冲区满而无法接收数据的情况,由于无接收中断产生,控制器也不会处理积压数据的现象,从而发生网卡假死的现象,系统无法接收数据。
 楼主| fst20220608 发表于 2022-6-10 10:35 | 显示全部楼层
不知道怎么改成固定IP,我刚入手,还不太熟悉。
 楼主| fst20220608 发表于 2022-6-10 10:41 | 显示全部楼层
连不上以太网之后,我运行debug,发现一直卡在EMAC_PhyInit()里的while (!(EMAC_MdioRead(PHY_STATUS_REG, EMAC_PHY_ADDR) & PHY_STATUS_LINK_VALID))
caoqing 发表于 2022-6-10 20:10 | 显示全部楼层
#define USE_DHCP    //main.c里面,删除即可
 楼主| fst20220608 发表于 2022-6-11 19:11 | 显示全部楼层
我在代码里没看到有#define USE_DHCP这行啊
  1. /*************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * @brief    This Ethernet sample tends to get a DHCP lease from DHCP
  5. *           server. And use 192.168.10.10 as IP address it failed to
  6. *           get a lease. After IP address configured, this sample can
  7. *           reply to PING packets.
  8. *
  9. *
  10. * [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2016 Nuvoton Technology Corp. All rights reserved.
  11. *****************************************************************************/
  12. #include <stdio.h>
  13. #include "NuMicro.h"
  14. #include "net.h"
  15. #include "led.h"
  16. #include "key.h"
  17. // Our MAC address
  18. uint8_t g_au8MacAddr[6] = {0x00, 0x00, 0x00, 0x59, 0x16, 0x88};
  19. // Our IP address
  20. uint8_t volatile g_au8IpAddr[4] = {0, 0, 0, 0};
  21. uint8_t auPkt[1514];
  22. uint32_t u32PktLen;
  23. // Descriptor pointers holds current Tx and Rx used by IRQ handler here.
  24. uint32_t u32CurrentTxDesc, u32CurrentRxDesc;
  25. void TMR0_IRQHandler(void)
  26. {
  27. //    static unsigned char count = 0;
  28.     //printf("%d sec\n", sec++);
  29.     // clear timer interrupt flag
  30.     TIMER_ClearIntFlag(TIMER0);
  31.     PH0=!PH0;
  32.     PH1=!PH1;
  33.     PH2=!PH2;
  34.     printf("1s enter TIM interrupt\r\n");
  35. //    __NOP();
  36. }
  37. /**
  38.   * @brief  EMAC Tx interrupt handler.
  39.   * @param  None
  40.   * @return None
  41.   */
  42. void EMAC_TX_IRQHandler(void)
  43. {
  44.     // Clean up Tx resource occupied by previous sent packet(s)
  45.     EMAC_SendPktDone();
  46. }
  47. /**
  48.   * @brief  EMAC Rx interrupt handler.
  49.   * @param  None
  50.   * @return None
  51.   */
  52. void EMAC_RX_IRQHandler(void)
  53. {
  54.     int i=0;
  55. //    while(1)
  56. //    {
  57.         printf("u32PktLen =%d\r\n",u32PktLen);
  58.         // Check if there's any packets available
  59.         if(EMAC_RecvPkt(auPkt, &u32PktLen) == 0)
  60.             return;
  61.             //break;
  62.         // Process receive packet
  63.         process_rx_packet(auPkt, u32PktLen);
  64.         for(i=0;i<u32PktLen;i++)
  65.         {
  66.             if(auPkt[i]==192)
  67.             {
  68.                 printf("IP address: %d.%d.%d.%d\n", auPkt[i], auPkt[i+1],auPkt[i+2], auPkt[i+3]);
  69.             }
  70.         }
  71.         // Clean up Rx resource occupied by previous received packet
  72.         EMAC_RecvPktDone();
  73. //    }
  74. }
  75. void SYS_Init(void)
  76. {
  77.     /* Unlock protected registers */
  78.     SYS_UnlockReg();
  79.     /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
  80.     PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
  81.     /* Enable External XTAL (4~24 MHz) */
  82.     CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
  83.     /* Waiting for 12MHz clock ready */
  84.     CLK_WaitClockReady( CLK_STATUS_HXTSTB_Msk);
  85.     /* Switch HCLK clock source to HXT */
  86.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HXT,CLK_CLKDIV0_HCLK(1));
  87.     /* Set core clock as PLL_CLOCK from PLL */
  88.     CLK_SetCoreClock(FREQ_192MHZ);
  89.     /* Set both PCLK0 and PCLK1 as HCLK/2 */
  90.     CLK->PCLKDIV = CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2;
  91.     /* Enable IP clock */
  92.     CLK_EnableModuleClock(UART0_MODULE);
  93.     CLK_EnableModuleClock(EMAC_MODULE);
  94.     /* Select IP clock source */
  95.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
  96.     // Configure MDC clock rate to HCLK / (127 + 1) = 1.5 MHz if system is running at 192 MHz
  97.     CLK_SetModuleClock(EMAC_MODULE, 0, CLK_CLKDIV3_EMAC(127));
  98.     /* Update System Core Clock */
  99.     /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
  100.     SystemCoreClockUpdate();
  101.     /* Set GPB multi-function pins for UART0 RXD and TXD */
  102.     SYS->GPB_MFPH &= ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
  103.     SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
  104.     // Configure RMII pins
  105.     SYS->GPA_MFPL |= SYS_GPA_MFPL_PA6MFP_EMAC_RMII_RXERR | SYS_GPA_MFPL_PA7MFP_EMAC_RMII_CRSDV;
  106.     SYS->GPC_MFPL |= SYS_GPC_MFPL_PC6MFP_EMAC_RMII_RXD1 | SYS_GPC_MFPL_PC7MFP_EMAC_RMII_RXD0;
  107.     SYS->GPC_MFPH |= SYS_GPC_MFPH_PC8MFP_EMAC_RMII_REFCLK;
  108.     SYS->GPE_MFPH |= SYS_GPE_MFPH_PE8MFP_EMAC_RMII_MDC |
  109.                      SYS_GPE_MFPH_PE9MFP_EMAC_RMII_MDIO |
  110.                      SYS_GPE_MFPH_PE10MFP_EMAC_RMII_TXD0 |
  111.                      SYS_GPE_MFPH_PE11MFP_EMAC_RMII_TXD1 |
  112.                      SYS_GPE_MFPH_PE12MFP_EMAC_RMII_TXEN;
  113.     // Enable high slew rate on all RMII TX output pins
  114.     PE->SLEWCTL = (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN10_Pos) |
  115.                   (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN11_Pos) |
  116.                   (GPIO_SLEWCTL_HIGH << GPIO_SLEWCTL_HSREN12_Pos);
  117.     /* Lock protected registers */
  118.     SYS_LockReg();
  119. }
  120. // This sample application can response to ICMP ECHO packets (ping)
  121. // IP address is configure with DHCP, but if a lease cannot be acquired, a static IP will be used.
  122. int main(void)
  123. {
  124.     SYS_Init();
  125.     UART_Open(UART0, 115200);
  126.     Led_init();
  127.     printf("led init \r\n");
  128.     key_init();
  129.     //TIM_init();
  130.     // Select RMII interface by default
  131.     EMAC_Open(g_au8MacAddr);
  132.     printf("EMAC open macaddr seccused\r\n");
  133.     // Init phy
  134.     EMAC_PhyInit();
  135.     NVIC_EnableIRQ(EMAC_TX_IRQn);
  136.     NVIC_EnableIRQ(EMAC_RX_IRQn);
  137.     EMAC_ENABLE_RX();
  138.     EMAC_ENABLE_TX();
  139.     printf("emaec enable rx dfksa \r\n");
  140.     if (dhcp_start() < 0)
  141.     {
  142.         // Cannot get a DHCP lease, use static IP.
  143.         printf("DHCP failed, use static IP 192.168.10.10\n");
  144.         g_au8IpAddr[0] = 0xC0;
  145.         g_au8IpAddr[1] = 0xA8;
  146.         g_au8IpAddr[2] = 0x0A;
  147.         g_au8IpAddr[3] = 0x0A;
  148.     }
  149.
  150.     while(1);
  151. }
  152. /*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
 楼主| fst20220608 发表于 2022-6-11 19:47 | 显示全部楼层
我读取EMAC_MdioRead(PHY_STATUS_REG, EMAC_PHY_ADDR);以太网连不上的时候,值是0x00007849,以太网连接成功的时候,值是0x0000786d,不懂为啥就是连不上
