[DemoCode下载]
M031的BSP升级了2022年3月
495|1
稳稳の幸福|  楼主 | 2022-6-16 20:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
https://www.nuvoton.com/tool-and-software/bsp-and-example-code/board-support-package/numicro-m0-board-support-package/
https://www.nuvoton.com/resource-download.jsp?tp_GUID=SW1820200914190828
下面这个是串口的发送与接收
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 4 $
* $Date: 18/07/12 9:43a $
* @brief
*           Transmit and receive data from PC terminal via the RS232 interface.
* @note
* SPDX-License-Identifier: Apache-2.0
* Copyright (C) 2018 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
#define RXBUFSIZE   1024
/* Global variables        */
volatile uint8_t g_u8RecData[RXBUFSIZE]  = {0};
volatile uint32_t g_u32comRbytes = 0;
volatile uint32_t g_u32comRhead  = 0;
volatile uint32_t g_u32comRtail  = 0;
volatile int32_t g_bWait         = TRUE;
/* Define functions prototype        */
void USCI_UART_TEST_HANDLE(void);
void USCI_UART_FunctionTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC clock (Internal RC 48MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable UART0 clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Switch UART0 clock source to HIRC */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
    /* Enable UUART0 clock */
    CLK_EnableModuleClock(USCI0_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and cyclesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
    SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk)) |
                    (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Set UUART0 multi-function pins */
    SYS->GPA_MFPH = (SYS->GPA_MFPH & ~(SYS_GPA_MFPH_PA9MFP_Msk | SYS_GPA_MFPH_PA10MFP_Msk)) |
                    (SYS_GPA_MFPH_PA9MFP_USCI0_DAT1 | SYS_GPA_MFPH_PA10MFP_USCI0_DAT0);
    /* Lock protected registers */
    SYS_LockReg();
void USCI0_Init()
    /* Init USCI        */
    /* Configure USCI0 as UART mode */
    UUART_Open(UUART0, 115200);
int main()
    SYS_Init();
    /* Init UART0 to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    /* Init USCI0 for test */
    USCI0_Init();
    /* SAMPLE CODE        */
    printf("\nUSCI UART Sample Program\n");
    /* USCI UART sample function */
    USCI_UART_FunctionTest();
    while (1);
/* ISR to handle USCI UART interrupt event        */
void USCI01_IRQHandler(void)
    USCI_UART_TEST_HANDLE();
/* USCI UART Callback function        */
void USCI_UART_TEST_HANDLE()
    uint8_t u8InChar = 0xFF;
    uint32_t u32IntSts = UUART_GET_PROT_STATUS(UUART0);
    if (u32IntSts & UUART_PROTSTS_RXENDIF_Msk)
        /* Clear RX end interrupt flag */
        UUART_CLR_PROT_INT_FLAG(UUART0, UUART_PROTSTS_RXENDIF_Msk);
        printf("\nInput:");
        /* Get all the input characters */
        while (!UUART_IS_RX_EMPTY(UUART0))
            /* Get the character from USCI UART Buffer */
            u8InChar = UUART_READ(UUART0);
            printf("%c ", u8InChar);
            if (u8InChar == '0')
                g_bWait = FALSE;
            /* Check if buffer full */
            if (g_u32comRbytes < RXBUFSIZE)
                /* Enqueue the character */
                g_u8RecData[g_u32comRtail] = u8InChar;
                g_u32comRtail = (g_u32comRtail == (RXBUFSIZE - 1)) ? 0 : (g_u32comRtail + 1);
                g_u32comRbytes++;
        printf("\nTransmission Test:");
/*  USCI UART Function Test        */
void USCI_UART_FunctionTest()
    uint32_t u32Temp;
    printf("+-----------------------------------------------------------+\n");
    printf("|  USCI UART Function Test                                  |\n");
    printf("|  Description :                                            |\n");
    printf("|    The sample code will print input char on terminal      |\n");
    printf("|    Please enter any to start     (Press '0' to exit)      |\n");
        Using a RS232 cable to connect USCI-UART0 and PC.
        USCI-UART0 is set to debug port. USCI-UART0 is enable RX end interrupt.
        When inputting char to terminal screen, RX end interrupt will happen and
        USCI-UART0 will print the received char on screen.
    /* Enable USCI UART interrupt */
    UUART_ENABLE_TRANS_INT(UUART0, UUART_INTEN_RXENDIEN_Msk);
    NVIC_EnableIRQ(USCI_IRQn);
    while (g_bWait)
        u32Temp = g_u32comRtail;
        if (g_u32comRhead != u32Temp)
            u8InChar = g_u8RecData[g_u32comRhead];
            while (UUART_IS_TX_FULL(UUART0)); /* Wait Tx is not full to transmit data */
            UUART_WRITE(UUART0, u8InChar);
            g_u32comRhead = (g_u32comRhead == (RXBUFSIZE - 1)) ? 0 : (g_u32comRhead + 1);
            g_u32comRbytes--;
    /* Disable USCI UART receive and transmit end interrupt */
    UUART_DISABLE_TRANS_INT(UUART0, UUART_INTEN_RXENDIEN_Msk | UUART_INTEN_TXENDIEN_Msk);
    NVIC_DisableIRQ(USCI_IRQn);
    g_bWait = TRUE;
    printf("\nUSCI UART Sample Demo End.\n");
/*** (C) COPYRIGHT 2018 Nuvoton Technology Corp. ***/
734774645| | 2022-6-17 10:57 | 只看该作者
回头下载一份。
