[应用方案] 差分ADC怎么用,
560|2
 楼主| asmine 发表于 2022-6-18 15:28 | 显示全部楼层 |阅读模式
怎么ADC还有差分的?
这是采集什么信号,
请大神聊聊
twjiang 发表于 2022-6-19 17:54 | 显示全部楼层
A differential ADC is helpful for measuring small signals that have a large DC offset - eg measuring changes of 100mv in the range 2.5 - 2.6v.
Readings for voltages lower than the offset are hardware dependent - can give negative readings, absolute values, or zero.
A typical application is in a load cell which has small voltage change at some DC offset.
关键是要理解 DC offset
差分ADC对于测量一个有较大DC offset的小信号很有帮助。
 楼主| asmine 发表于 2022-6-20 21:13 | 显示全部楼层
我对DC offset的理解只是直流偏置,不知道这样理解对不对。
描述的话,
就是在一个直流分量的基础上,有一个交流小信号。
针对这种信号做采集?
