- void BLDCMotorPrepareCommutation(u8 pos, TIMOCMODE_Typedef TIM_CHxMode, TIMOCMODE_Typedef TIM_CHxNMode)
- if (pos == 0){
- /* Channel1 configuration: CH1 output: PWM */
- TIM_SelectOCxM (TIM1, TIM_Channel_1, TIM_CHxMode);
- TIM_CCxCmd (TIM1, TIM_Channel_1, TIM_CCx_Enable);
- TIM_CCxNCmd (TIM1, TIM_Channel_1, TIM_CCxN_Disable);
- /* Channel2 configuration: CH2N output: PWM */
- TIM_SelectOCxM (TIM1, TIM_Channel_2, TIM_CHxNMode);
- TIM_CCxCmd (TIM1, TIM_Channel_2, TIM_CCx_Disable);
- TIM_CCxNCmd (TIM1, TIM_Channel_2, TIM_CCxN_Enable);
- /* Channel3 configuration: CH3 None */
- TIM_CCxCmd (TIM1, TIM_Channel_3, TIM_CCx_Disable);
- TIM_CCxNCmd (TIM1, TIM_Channel_3, TIM_CCxN_Disable);
- else if (pos == 1){
- /* Channel2 configuration: CH2 None */
- TIM_CCxNCmd (TIM1, TIM_Channel_2, TIM_CCxN_Disable);
- /* Channel3 configuration: CH3N output: PWM */
- TIM_SelectOCxM (TIM1, TIM_Channel_3, TIM_CHxNMode);
- TIM_CCxNCmd (TIM1, TIM_Channel_3, TIM_CCxN_Enable);
- else if (pos == 3){
- /* Channel1 configuration: CH1 None */
- TIM_CCxCmd (TIM1, TIM_Channel_1, TIM_CCx_Disable);
- /* Channel2 configuration: CH2 output: PWM */
- TIM_SelectOCxM (TIM1, TIM_Channel_2, TIM_CHxMode);
- TIM_CCxCmd (TIM1, TIM_Channel_2, TIM_CCx_Enable);
- TIM_SelectOCxM(TIM1, TIM_Channel_3, TIM_CHxNMode);
- TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Enable);
- else if (pos == 7){
- /* Channel1 configuration: CH1N output: PWM */
- TIM_SelectOCxM(TIM1, TIM_Channel_1, TIM_CHxNMode);
- TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Enable);
- TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_CHxMode);
- TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Disable);
- TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Disable);
- else if (pos == 6){
- /* Channel3 configuration: CH3 output: PWM */
- TIM_SelectOCxM(TIM1, TIM_Channel_3, TIM_CHxMode);
- TIM_CCxCmd (TIM1, TIM_Channel_3, TIM_CCx_Enable);
- else if (pos == 4){
- TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Disable);
- TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_CHxNMode);
- TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Enable);
