[其他ST产品] FreeRTOS中portDISABLE_INTERRUPTS()函数无法guanb
923|2
 楼主| duo点 发表于 2022-7-6 11:00 | 显示全部楼层 |阅读模式
参考原子哥《STM32F429 FreeRTOS开发手册》教程,第四章FreeRTOS中断配置和临界段实验,我利用cubemx+f407创建工程,创建start_task和isr_task任务,在isr_task任务中portDISABLE_INTERRUPTS()函数无法关闭TIM中断(TIM3 中断优先级设置为4,TIM5中断优先级设置为6),求大神赐教。代码如下:
1、main函数初始化TIM和FreeRTOS
[mw_shl_code=applescript,true] MX_TIM3_Init();
MX_TIM5_Init();
/* Call init function for freertos objects (in freertos.c) */
MX_FREERTOS_Init();
/* Start scheduler */
osKernelStart();[/mw_shl_code]
2、任务函数
[mw_shl_code=applescript,true]/* start_task function */
void start_task(void const * argument)
/* USER CODE BEGIN start_task */
/* Infinite loop */
printf("start task\r\n");
taskENTER_CRITICAL(); //??è?áù????
printf("start task ??è?áù????\r\n");
osThreadDef(IsrIask, isr_task, osPriorityHigh, 0, 128);
IsrIaskHandle = osThreadCreate(osThread(IsrIask), NULL);
vTaskDelete(S
atartTaskHandle); //é?3y?aê?è???
printf("start task í?3?áù????\r\n");
taskEXIT_CRITICAL(); //í?3?áù????
/* USER CODE END start_task */
/* isr_task function */
void isr_task(void const * argument)
/* USER CODE BEGIN isr_task */
/* Infinite loop */
static uint32_t total_num = 0;
for(;;)
total_num+=1;
printf("total_num = %d\r\n",total_num);
if(total_num==5)
printf("1?±??D??.............\r\n");
portDISABLE_INTERRUPTS();        //1?±??D??
osDelay(5000);        //?óê±5s
printf("′ò?a?D??.............\r\n");        //′ò?a?D??
portENABLE_INTERRUPTS();
LEDx_StateSet(LED2,LED_TOGGLE);
osDelay(100);
/* USER CODE END isr_task */
}[/mw_shl_code]
3、定时器中断服务函数
[mw_shl_code=applescript,true]void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
if(htim==(&htim3))
printf("TIM3ê?3?.......\r\n");
else if(htim==(&htim5))
printf("TIM5ê?3?.......\r\n");
}[/mw_shl_code]
huahuagg 发表于 2022-7-6 22:07 | 显示全部楼层
对这个RTOS无研究,期待大神来分析一下咋回事
大佬,你解决了吗?  发表于 2025-2-28 21:53
