帮我看下这个代码有什么问题?为什么读不出高16位
1109|0
 楼主| fengyu2513 发表于 2022-7-25 18:17 | 显示全部楼层 |阅读模式
fsmc 总线去读取 data_read高位时无法读取出来,一直是0。
这个总线读取是正确的,低16位正确的,高16位读不出来。
就是 12'd151:和12'd154  读回来的是0值,不知道是和原因
module code_top(
              clk_100,
                                  rst_n,
                                        csn,
                                  rden,
                                  wren,
                                  CODE_A,
                                        CODE_B,
                                        CODE_Z,
                                        address,
                                        data_in,
                                  data_out
        assign wr = !(csn | wren);
    assign rd = !(csn & rden);
input clk_100,rst_n,rden,wren;
input [3:0] CODE_A,CODE_B,CODE_Z;
input [11:0] address;
input [15:0] data_in;
output  [15:0] data_out;
input csn;
wire [33:0] code_data[3:0];
wire [15:0] z_counter[3:0];
reg [33:0] data_read[3:0];
reg [15:0] z_read[3:0];
encode code_x(
                     .clk_100M(clk_100),
                                         .rst_n(rst_n),
                                         .A_in(CODE_A[0]),
                                         .B_in(CODE_B[0]),
                                         .Z_in(CODE_Z[0]),
                                         .code_data(code_data[0]),
                                         .z_counter(z_counter[0])
reg [15:0]DB_OUT;
reg [15:0]data_read_h;
always @(rd or !rst_n)
begin
          if(!rst_n)
          begin
                     DB_OUT<=16'hzzzz;
                     data_read_h<= 16'h0;
         end
          else
                        begin
                                case (address)
                                        12'd150:
                                        begin
                                                DB_OUT  <=  data_read[0][17:2];
                                                data_read_h<= data_read[0][33:18];
                                        end
                                        12'd151:
                                        begin
                                                DB_OUT  <=data_read_h;    //x    16'd111;//
                                        end
                                        12'd152:DB_OUT  <= z_read[0];
                                        12'd153:
                                        begin
                                                DB_OUT  <= data_read[1][17:2];
                                                data_read_h<= data_read[1][33:18];
                                        end
                                        12'd154:
                                        begin
                                                DB_OUT  <=data_read_h;          //y    code_data[1][33:18];//
                                        end
                                        12'd155:DB_OUT  <=z_read[1];
                                        12'd156:
                                        begin
                                                DB_OUT  <= data_read[2][17:2];
                                                data_read_h<= data_read[2][33:18];
                                        end
                                        default :
                                                        begin
        DB_OUT <= 16'hzzzz;
        code_data_h <= 16'h0000;
                                                        end
                                endcase
                        end
end
assign data_out = rd ? DB_OUT : 16'hzzzz;
always@(posedge clk_100 or negedge rst_n)
begin
         if(!rst_n)
          begin
                        data_read[0] <= 33'd0;
                data_read[1] <=  33'd0;
                data_read[2] <=  33'd0;
                data_read[3] <=  33'd0;
                z_read[0] <=  16'd0;
                z_read[1] <=  16'd0;
                z_read[2] <=16'd0;
                z_read[3] <= 16'd0;
//          code_data_h <= 16'h1;
         end
          else
          begin
                data_read[0] <= code_data[0];
                data_read[1] <= code_data[1];
                data_read[2] <= code_data[2];
                data_read[3] <= code_data[3];
                z_read[0] <= z_counter[0];
                z_read[1] <= z_counter[1];
                z_read[2] <= z_counter[2];
                z_read[3] <= z_counter[3];
                end
end
