使用了RTC ALARM A闹钟唤醒STM32F030c8t6和WAKEUP引脚外部唤醒 ,当外部唤醒以后进行校准时间,发现一小时能差8分钟。下面是我的RTC配置 和系统时间配置
- oid RCC_Configuration(void)
- /* RCC system reset(for debug purpose) */
- RCC_DeInit();
- RCC_LSICmd(ENABLE);
- while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//等待HSI就绪
- RCC_HCLKConfig(RCC_SYSCLK_Div1);//配置AHB Prescaler为1(根据cubemx的时钟图看的)-->得到HCLK 8 M
- RCC_PCLKConfig(RCC_HCLK_Div1);//配置APB1 Prescaler 为1 得到 PCLK1 = 8M-->同时APB1 外设时钟和和APB1上的定时器->8Mhz
- // RCC_PLLConfig(RCC_PLLSource_HSI_Div2, RCC_PLLMul_8);//HSI RC(8MHZ) /2 * 8->PLLCLK = 32 Mhz
- // RCC_PLLCmd(ENABLE);
- // RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//将 PLLCLK作为系统时钟
- RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//将内部时钟作为系统时钟 ->8mhz
- /* 使能APB1时钟 */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);//使能 PWR时钟
- void RTC_Configuration(void)
- /* Enable the PWR clock */
- /* Allow access to RTC */
- PWR_BackupAccessCmd(ENABLE);
- #if defined (RTC_CLOCK_SOURCE_LSI) /* LSI used as RTC source clock*/
- /* The RTC Clock may varies due to LSI frequency dispersion. */
- /* Enable the LSI OSC */
- /* Wait till LSI is ready */
- while(RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET)
- /* Check if the StandBy flag is set */
- if (PWR_GetFlagStatus(PWR_FLAG_SB) != RESET)
- /* Clear StandBy flag */
- PWR_ClearFlag(PWR_FLAG_SB);
- /* Check if the StandBy flag is cleared */
- while(1);
- RTC_WaitForSynchro();
- /* No need to configure the RTC as the RTC config(clock source, enable,
- prescaler,...) are kept after wake-up from STANDBY */
- /* Select the RTC Clock Source */
- RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);
- SynchPrediv = 0x18F;
- AsynchPrediv = 0x63;
- #elif defined (RTC_CLOCK_SOURCE_LSE) /* LSE used as RTC source clock */
- /* Enable the LSE OSC */
- RCC_LSEConfig(RCC_LSE_ON);
- /* Wait till LSE is ready */
- while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET)
- RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
- SynchPrediv = 0xFF;
- AsynchPrediv = 0x7F;
- #else
- #error Please select the RTC Clock source inside the main.c file
- #endif /* RTC_CLOCK_SOURCE_LSI */
- /* Enable the RTC Clock */
- RCC_RTCCLKCmd(ENABLE);
- /* Wait for RTC APB registers synchronisation */
