usb接口读写
1500|7
zhanglli|  楼主 | 2012-4-8 15:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求usb接口读写的资料,文档、代码均可。
lium| | 2012-4-8 15:02 | 只看该作者
你可以看看cypress公司EZUSB芯片AN2131QC全部的文档
guoyt| | 2012-4-8 15:05 | 只看该作者
CY8C24x94的usb中文资料
USBFS数据手册.pdf
338.8 KB
hanwe| | 2012-4-8 15:06 | 只看该作者
对,有一个叫做EzMr的主机程序,是一个VC++程序
yufe| | 2012-4-8 15:08 | 只看该作者
ddk下有不少例子
思路大体如下:
<1> .   打开设备,获取设备句柄CreateFile( "\\\\.\\ezusb-0 ",.......);
<2> .   设置Interface;获取   PipesInfo;
<3> .   用   Bulk   或其它方式传输数据;
<4> .   关闭设备。
llia| | 2012-4-8 15:09 | 只看该作者
HANDLE   OpenDevice(LPGUID   pGuid,   char   *outNameBuf)
HANDLE   hOut   =   INVALID_HANDLE_VALUE;
HDEVINFO   hardwareDeviceInfo;
SP_INTERFACE_DEVICE_DATA   deviceInfoData;
hardwareDeviceInfo   =   SetupDiGetClassDevs   (pGuid,   NULL,   NULL,   (DIGCF_PRESENT   |   DIGCF_INTERFACEDEVICE));
deviceInfoData.cbSize   =   sizeof   (SP_INTERFACE_DEVICE_DATA);
if   (SetupDiEnumDeviceInterfaces   (hardwareDeviceInfo,   0,   pGuid,   0,   &deviceInfoData))
hOut   =   OpenOneDevice   (hardwareDeviceInfo,   &deviceInfoData,   outNameBuf);
if   (hOut==INVALID_HANDLE_VALUE)
return   INVALID_HANDLE_VALUE;
DWORD   reErr   =   GetLastError(   );
SetupDiDestroyDeviceInfoList   (hardwareDeviceInfo);
return   hOut;
HANDLE   OpenOneDevice(HDEVINFO   HardwareDeviceInfo,   PSP_INTERFACE_DEVICE_DATA   DeviceInfoData,   char   *devName)
PSP_INTERFACE_DEVICE_DETAIL_DATA   functionClassDeviceData   =   NULL;
ULONG   predictedLength   =   0;
ULONG   requiredLength   =   0;
//   allocate   a   function   class   device   data   structure   to   receive   the   goods   about   this   particular   device.
SetupDiGetInterfaceDeviceDetail   (HardwareDeviceInfo,   DeviceInfoData,   NULL,   0,   &requiredLength,   NULL);
predictedLength   =   requiredLength;
//   sizeof   (SP_FNCLASS_DEVICE_DATA)   +   512;
functionClassDeviceData   =   (PSP_INTERFACE_DEVICE_DETAIL_DATA)malloc   (predictedLength);
functionClassDeviceData-> cbSize   =   sizeof   (SP_INTERFACE_DEVICE_DETAIL_DATA);
//   Retrieve   the   information   from   Plug   and   Play.
if   (!SetupDiGetInterfaceDeviceDetail(
HardwareDeviceInfo,
DeviceInfoData,
functionClassDeviceData,
predictedLength,
&requiredLength,
NULL))
free(functionClassDeviceData);
strcpy(devName,functionClassDeviceData-> DevicePath);
printf( "Attempting   to   open   %s\n ",   devName);
hOut   =   CreateFile   (functionClassDeviceData-> DevicePath,
GENERIC_READ   |   GENERIC_WRITE,
FILE_SHARE_READ   |   FILE_SHARE_WRITE,
NULL,
OPEN_EXISTING,
0,
NULL);
if   (INVALID_HANDLE_VALUE   ==   hOut)
printf( "FAILED   to   open   %s\n ",   devName);
return   hOut;
HANDLE   hDEV   =   OpenDevice((LPGUID)&GUID_BUS_UMSS,   completeDeviceName);
if   (hDEV==INVALID_HANDLE_VALUE)
return;
DeviceIoControl   (
hDEV,
IOCTL_Vender_VCMD_WRITE,
buf,
31,   //CBW
buf,
13,   //   Data   +   CSW
(LPDWORD)&nBytes,
NULL
zhanglli|  楼主 | 2012-4-8 15:11 | 只看该作者
嗯,我了解了
结贴了
