GD32F330C8T6 TIMER0 CH3 PWM波输入捕获配置问题
1183|0
 楼主| 糖长老 发表于 2022-8-11 17:15 | 显示全部楼层 |阅读模式
配置的定时器0通道3 捕获PWM波无法捕获到,一直进中断,如下是我定时器的代码,不知道哪里的配置有问题,请求大神指导,  timer_ic_parameter_struct timer_icinitpara;
    timer_parameter_struct timer_initpara;
    rcu_periph_clock_enable(RCU_TIMER0);
    timer_deinit(TIMER0);
    timer_initpara.prescaler         = 83; //预分频
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 65535;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER0, &timer_initpara);
    /* TIMER0 configuration */
    /* TIMER0 CH3 PWM input capture configuration */
    timer_icinitpara.icpolarity  = TIMER_IC_POLARITY_RISING;
    timer_icinitpara.icselection = TIMER_IC_SELECTION_DIRECTTI;
    timer_icinitpara.icprescaler = TIMER_IC_PSC_DIV1;
    timer_icinitpara.icfilter    = 0x0;
    timer_input_pwm_capture_config(TIMER0, TIMER_CH_3, &timer_icinitpara);
    /* slave mode selection: TIMER0 */
    timer_input_trigger_source_select(TIMER0, TIMER_SMCFG_TRGSEL_CI0FE0);
    timer_slave_mode_select(TIMER0, TIMER_SLAVE_MODE_RESTART);
    /* select the master slave mode */
    timer_master_slave_mode_config(TIMER0, TIMER_MASTER_SLAVE_MODE_ENABLE);
    /* auto-reload preload enable */
    timer_auto_reload_shadow_enable(TIMER0);
    /* clear channel 0 interrupt bit */
    timer_interrupt_flag_clear(TIMER0, TIMER_INT_CH3);
    /* channel 0 interrupt enable */
    timer_interrupt_enable(TIMER0, TIMER_INT_CH3);
    /* TIMER0 counter enable */
    timer_enable(TIMER0);
其中IO口和中断优先级已经确认配置无误,同时发现当前版本库这个函数timer_input_pwm_capture_config(TIMER0, TIMER_CH_3, &timer_icinitpara);的参数上没有TIMER_CH_3这一输入源,可能问题出现在这里,搞不懂。
