[PIC®/AVR®/dsPIC®产品] 求助:MPLAB新建工程编译错误recipe for target
1244|3
 楼主| 13775172169 发表于 2022-8-23 13:17 | 显示全部楼层 |阅读模式
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'F:/pic/76.X'
make  -f nbproject/Makefile-default.mk dist/default/production/76.X.production.hex
make[2]: Entering directory 'F:/pic/76.X'
"C:\Program Files\Microchip\xc8\v2.40\bin\xc8-cc.exe"  -mcpu=16F1513 -c   -mdfp="C:/Program Files/Microchip/MPLABX/v6.00/packs/Microchip/PIC12-16F1xxx_DFP/1.3.90/xc8"  -fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default  -msummary=-psect,-class,+mem,-hex,-file  -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall -mdefault-config-bits   -std=c99 -gdwarf-3 -mstack=compiled:auto:auto     -o build/default/production/main.p1 main.c
::: error: (900) exec failed: C:\Program Files\Microchip\xc8\v2.40\pic\bin\clist
(908) exit status = 1
nbproject/Makefile-default.mk:107: recipe for target 'build/default/production/main.p1' failed
make[2]: Leaving directory 'F:/pic/76.X'
nbproject/Makefile-default.mk:91: recipe for target '.build-conf' failed
make[1]: Leaving directory 'F:/pic/76.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[2]: *** [build/default/production/main.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
编译已失败 (退出值2, 总时间: 480ms)
搞半天了求助
前几天还好好的  昨天开始就这样了
 楼主| 13775172169 发表于 2022-8-23 15:21 | 显示全部楼层
重新安装了xc8编译器 解决了
lcczg 发表于 2022-8-26 09:38 | 显示全部楼层
是的,在编译器手册里也提到重装编译器
