[应用方案] 打印 上一主题 下一主题 开启左侧[M480] PLL and PWM Clock Setting
786|1
 楼主| cr315 发表于 2022-9-2 15:29 | 显示全部楼层 |阅读模式
Application: Two applications that can list clock setting to generate target PLL and PWM settings.
NuMicro® M480 series consist of one PLL sourced from HIRC or HXT, allows CPU operation up to the maximum CPU frequency without the need for a high-frequency crystal. And the M480 can generate PWM waveform from BPWM and EPWM.
These two example codes list the PLL and BPWM/EPWM settings can generate the target output frequency from designated input clock frequency.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0108110124
