[技术问答] [M480] Combine Color Data by PDMA Stride Mode
758|1
 楼主| cr315 发表于 2022-9-3 15:00 | 显示全部楼层 |阅读模式
ar, AN, DM, mb, pd, DMA
Application: Combine red, green and blue data into a RGB color array by PDMA stride mode
BSP Version: M480 Series BSP CMSIS V3.04.000
Hardware: NuMaker-ETM-M487 v1.2
This example code shows how to combine red, green and blue data into a RGB color array by PDMA stride mode of M480 series.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0326140008
yangjiaxu 发表于 2023-10-24 11:56 | 显示全部楼层
用PDMA来实现对RGB实现驱动是吧,这个确实是个好例程,支持一下
