[N32WBxxx] 用户自己的程序,如果安排一些耗时的工作?
1537|9
 楼主| zhanxiao 发表于 2022-9-24 16:07 | 显示全部楼层 |阅读模式
我现在只想到在ble ready后调用定时器
先定义 msg
enum user_msg_id
    APP_USER_DEMO_EVE = APP_FREE_EVE_FOR_USER,
    APP_CUSTS_2MS_MAIN_LOOP,//4 2ms
    APP_CUSTS_5MS_AD,
    APP_CUSTS_10MS_LED,
    APP_CUSTS_10MS_KEY,
    APP_CUSTS_10MS_WIRELESS,
    APP_CUSTS_10MS_MISC,
    APP_CUSTS_100MS_HINT,
然后在APP_BLE_OS_READY调用v_ble_init_ok_callback启动定时器
void v_ble_init_ok_callback(void)
        ke_timer_set(APP_CUSTS_100MS_HINT, TASK_APP, 101);
        ke_timer_set(APP_CUSTS_10MS_MISC, TASK_APP, 13);
        ke_timer_set(APP_CUSTS_10MS_KEY, TASK_APP, 12);
        ke_timer_set(APP_CUSTS_10MS_WIRELESS, TASK_APP, 11);
        ke_timer_set(APP_CUSTS_10MS_LED, TASK_APP, 10);
        ke_timer_set(APP_CUSTS_5MS_AD, TASK_APP, 5);
        ke_timer_set(APP_CUSTS_2MS_MAIN_LOOP, TASK_APP, 2);
然后在msg的回调里面处理数据:
void app_user_msg_handler(ke_msg_id_t const msgid, void const *p_param)
    #ifndef USE_RWIP
    switch (msgid)
            //case APP_CUSTS_TEST_EVT:
            //        break;
            default:
                    break;
        #else
        extern void v_cust_handler(ke_msg_id_t const msgid);
        v_cust_handler(msgid);
        #endif
        extern uint8_t fg_wakeup_by_acc;
        if(WORK_ST_OFF==e_flow_work_st)
        else
                        switch ( msgid )
                            case APP_CUSTS_2MS_MAIN_LOOP:
                                        v_2ms_main_loop();
                                break;
                            case APP_CUSTS_5MS_AD:
                                        v_5ms_ad_loop();
                                break;
                            case APP_CUSTS_10MS_LED:
                                        v_10ms_led_process();
                                break;
                            case APP_CUSTS_10MS_KEY:
                                        v_10ms_key_process();
                                break;
                            case APP_CUSTS_10MS_WIRELESS:
                                        v_10ms_wireless_process();
                                break;
                            case APP_CUSTS_10MS_MISC:
                                v_10ms_misc_process();
                                break;
                            case APP_CUSTS_100MS_HINT:
                                v_100ms_loop_process();
                                        #ifdef IWDG_ADDED
                                        IWDG_ReloadKey();
                                        #endif
                                break;
                            default:
                                break;
我的led处理里面比较耗时,但是也最多2ms,有一个uart中断,中断中只是idle收DMA接收到的数据(rdtss的例程里面的)
systick 中断,中断中只有变量简单操作
#define TIMER_GO(timer)                 {if(timer>TIMER_STOP) timer++;}
void tick_handler (void)
        d_system_time_clock++;
        if (delay_timer > TIMER_STOP)
                delay_timer++;
        if (timer_10ms_tick < 14)
                timer_10ms_tick++;
        else
                timer_10ms_tick = 0;
                fg_10ms_trigger = TRUE;
        if (timer_2ms_tick < 1)
                timer_2ms_tick++;
        else
                timer_2ms_tick = 0;
                fg_2ms_trigger = TRUE;
        if (timer_5ms_tick < 6)
                timer_5ms_tick++;
        else
                timer_5ms_tick = 0;
                fg_5ms_trigger = TRUE;
        if (timer_100ms_tick < 100)
                timer_100ms_tick++;
        else
                timer_100ms_tick = 0;
                fg_100ms_trigger = TRUE;
        if (timer_1000ms_tick < 1000)
                timer_1000ms_tick++;
        else
                fg_1000ms_trigger=TRUE;
                timer_1000ms_tick=0;
        TIMER_GO(w_refresh_guard_timer);
        TIMER_GO(w_system_sleep_timer);
        TIMER_GO(w_power_delay_timer);
        TIMER_GO(w_recv_bt_timerout);
        TIMER_GO(w_send_timer_out);
还有一个IO中断,
void v_wakeup_on(void)
         if ( EXTI_GetITStatus(KEY_INPUT_EXTI_LINE)!= RESET)
            if(now_not_insleep==FALSE)
                       fg_wakeup_by_acc=TRUE;
        EXTI_ClrITPendBit(KEY_INPUT_EXTI_LINE);
我使用发现有2个问题:
1:time定时不准,明显慢
2:遇到死机的情况(几个小时可能会出现,没有手机连接过蓝牙),因为所有IO都被使用了,无法跟踪,
版主,有什么建议?
Diyer123 发表于 2022-9-24 17:10 | 显示全部楼层
分时间片。不要那种循环式的delay()
 楼主| zhanxiao 发表于 2022-9-24 17:21 来自手机 | 显示全部楼层
没有delay
 楼主| zhanxiao 发表于 2022-9-24 17:23 来自手机 | 显示全部楼层
用户程序没有任何这种死等的delay,只是计算耗时
ASHYLAI 发表于 2022-9-25 14:11 | 显示全部楼层
我觉得你还是用操作系统好点。
 楼主| zhanxiao 发表于 2022-9-26 09:27 | 显示全部楼层
我觉得你还是用操作系统好点。
这个就是用的n32wb031里面的RWIP
N32BLE 发表于 2022-9-26 16:16 | 显示全部楼层
请使用定时器创建函数ns_timer_create进行用户任务的切换。
N32BLE 发表于 2022-9-26 16:18 | 显示全部楼层
软件定时器相对硬件定时器来说,会有一定误差。
没完 发表于 2023-2-1 15:21 | 显示全部楼层
解决了吗,我用ke_timer_set函数,定时1s,实测是7s
 楼主| zhanxiao 发表于 2024-4-1 15:15 | 显示全部楼层
我已经放弃这个芯片了,换方案了,
