[开发板与模块] 【ESK32-30519 + ESK32-21001测评】+a/d及数码管显示
1388|5
 楼主| emanages 发表于 2022-10-2 14:15 | 显示全部楼层 |阅读模式
#申请原创#非常荣幸能够获得本次的测试的机会,非常感谢21IC和合泰。本次主要时测试12bit的ADC,并用数码管显示。
收到开发板后,焊接了排针,整个板子很大气:如下
ADC采样利用底板的变阻器来测试:
数码管的原理图:
程主要实现的时系统滴答定时器开启,ADC中断采样以及数码管的显示:
开启系统滴答定时器程序如下:
SYSTICK_ClockSourceConfig(SYSTICK_SRC_STCLK);       // Default : CK_AHB/8
  SYSTICK_SetReloadValue(SystemCoreClock / 8 / 1000); // (CK_AHB/8/1000) = 1ms on chip
  SYSTICK_IntConfig(ENABLE);  //开启系统滴答定时器
SYSTICK_CounterCmd(SYSTICK_COUNTER_CLEAR);
   SYSTICK_CounterCmd(SYSTICK_COUNTER_ENABLE);
ADC初始化:
void ADC_Configuration(void)
  { /* Enable peripheral clock        */
    CKCU_PeripClockConfig_TypeDef CKCUClock = {{ 0 }};
    CKCUClock.Bit.AFIO = 1;
    CKCUClock.Bit.HTCFG_ADC_IPN = 1;
    CKCU_PeripClockConfig(CKCUClock, ENABLE);
  /* Configure AFIO mode as ADC function        */
  AFIO_GPxConfig(HTCFG_VR_GPIO_ID, HTCFG_VR_AFIO_PIN, HTCFG_ADC_AFIO_MODE);
  { /* ADC related settings        */
    /* CK_ADC frequency is set to (CK_AHB / 64)                                                             */
    CKCU_SetADCnPrescaler(HTCFG_ADC_CKCU_ADCPRE, CKCU_ADCPRE_DIV64);
    /* Continuous mode, sequence length = 1        */
    ADC_RegularGroupConfig(HTCFG_ADC_PORT, CONTINUOUS_MODE, 1, 0);
    /* ADC conversion time = (Sampling time + Latency) / CK_ADC = (1.5 + ADST + 12.5) / CK_ADC              */
    /* Set ADST = 0, sampling time = 1.5 + ADST                                                             */
    #if (LIBCFG_ADC_SAMPLE_TIME_BY_CH)
      // The sampling time is set by the last parameter of the function "ADC_RegularChannelConfig()".
    #else
    ADC_SamplingTimeConfig(HTCFG_ADC_PORT, 0);
    #endif
    /* Set ADC conversion sequence as channel n                                                             */
    ADC_RegularChannelConfig(HTCFG_ADC_PORT, HTCFG_VR_ADC_CH, 0, 0);
    /* Set software trigger as ADC trigger source                                                           */
    ADC_RegularTrigConfig(HTCFG_ADC_PORT, ADC_TRIG_SOFTWARE);
  /* Enable ADC single end of conversion interrupt                                                          */
  ADC_IntConfig(HTCFG_ADC_PORT, ADC_INT_SINGLE_EOC, ENABLE);
  /* Enable the ADC interrupts        */
  NVIC_EnableIRQ(HTCFG_ADC_IRQn);
数码管初始化:
unsigned char NumberChar[]={
  /* a: Seg4(0x10), b: Seg7(0x80), c: Seg2(0x04), d: Seg5(0x20),
     e: Seg3(0x08), f: Seg0(0x01), g: Seg6(0x40), dp: Seg1(0x02) */
  0xBD, /* '0' = a+b+c+d+e+f      = 0x10 + 0x80 + 0x04 + 0x20 + 0x08 + 0x01               = 0xBD */
  0x84, /* '1' =   b+c+           =        0x80 + 0x04                                    = 0x84 */
  0xF8, /* '2' = a+b  +d+e  +g    = 0x10 + 0x80 +        0x20 + 0x08 +      + 0x40        = 0xF8 */
  0xF4, /* '3' = a+b+c+d    +g    = 0x10 + 0x80 + 0x04 + 0x20 +             + 0x40        = 0xF4 */
  0xC5, /* '4' =   b+c    +f+g    =        0x80 + 0x04               + 0x01 + 0x40        = 0xC5 */
  0x75, /* '5' = a  +c+d  +f+g    = 0x10        + 0x04 + 0x20        + 0x01 + 0x40        = 0x75 */
  0x7D, /* '6' = a  +c+d+e+f+g    = 0x10        + 0x04 + 0x20 + 0x08 + 0x01 + 0x40        = 0x7D */
  0x95, /* '7' = a+b+c    +f      = 0x10 + 0x80 + 0x04               + 0x01               = 0x95 */
  0xFD, /* '8' = a+b+c+d+e+f+g    = 0x10 + 0x80 + 0x04 + 0x20 + 0x08 + 0x01 + 0x40        = 0xFD */
  0xF5, /* '9' = a+b+c+d  +f+g    = 0x10 + 0x80 + 0x04 + 0x20        + 0x01 + 0x40        = 0xF5 */
  0x02  /* '.' =               dp =                                                  0x02 = 0x02 */
void LEDC_Configuration(void)
  LEDC_InitTypeDef LEDC_InitStruct;
  /* Turn on the APB clock of LEDC. */
  CKCU_PeripClockConfig_TypeDef CKCUClock = {{0}};
  CKCUClock.Bit.LEDC       = 1;
  /* Frame = fCK_LED / (LEDC_DutyClockNumber * COM Number) */
  /*       = 1600 / (8*4)  =  50Hz */
  LEDC_InitStruct.LEDC_ClockSource    = LEDC_SRC_LSI;                    /* LSI = 32Khz */
  LEDC_InitStruct.LEDC_ClockPrescaler = HTCFG_LEDC_CLOCK_PRESCAL - 1;    /* fCK_LED = 32Khz / 20 = 1600 Hz */
  LEDC_InitStruct.LEDC_DutyClockNumber = HTCFG_LEDC_DUTY_CLOCK_NUMBER;   /* Duty CLock Number = 8 Clock */
  LEDC_InitStruct.LEDC_COMxEN = HTCFG_LEDC_COM1EN | HTCFG_LEDC_COM2EN |\
                                HTCFG_LEDC_COM3EN | HTCFG_LEDC_COM4EN;   /* Enable COMx */
  /* Change the brightness, the parameter range is 0~Duty (CLock Number-1.) */
  /* 0: the brightest, 7: the darkest.                                      */
  LEDC_InitStruct.LEDC_DeadTime = 0;
  LEDC_Init(&LEDC_InitStruct);                                            /* LEC initialization. */
  /* Set the LEDC mode to COMMON_CATHODE. */
  LEDC_SetPolarityMode(HTCFG_LEDC_COM1POL | HTCFG_LEDC_COM2POL | HTCFG_LEDC_COM3POL | HTCFG_LEDC_COM4POL,
                       LEDC_SEG0POL | LEDC_SEG1POL | LEDC_SEG2POL | LEDC_SEG3POL |\
                       LEDC_SEG4POL | LEDC_SEG5POL | LEDC_SEG6POL | LEDC_SEG7POL,
                       COMMON_CATHODE);
  LEDC_IntConfig(ENABLE);                                                 /* Enable frame interrupt. */
  NVIC_EnableIRQ(LEDC_IRQn); /* Enable LECD IRQ. */
  LEDC_Cmd(ENABLE);          /* LEDC Start. */
void GPIO_Configuration(void)
  /* Turn on the APB clock of AFIO. */
  /* SEG0~7 */
  AFIO_GPxConfig(HTCFG_LEDC_SEG0_GPIO_ID, HTCFG_LEDC_SEG0_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_SEG1_GPIO_ID, HTCFG_LEDC_SEG1_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_SEG2_GPIO_ID, HTCFG_LEDC_SEG2_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_SEG3_GPIO_ID, HTCFG_LEDC_SEG3_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_SEG4_GPIO_ID, HTCFG_LEDC_SEG4_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_SEG5_GPIO_ID, HTCFG_LEDC_SEG5_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_SEG6_GPIO_ID, HTCFG_LEDC_SEG6_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_SEG7_GPIO_ID, HTCFG_LEDC_SEG7_AFIO_PIN, AFIO_FUN_LEDC);
  /* COM0~4 */
  AFIO_GPxConfig(HTCFG_LEDC_COM0_GPIO_ID, HTCFG_LEDC_COM0_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_COM1_GPIO_ID, HTCFG_LEDC_COM1_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_COM2_GPIO_ID, HTCFG_LEDC_COM2_AFIO_PIN, AFIO_FUN_LEDC);
  AFIO_GPxConfig(HTCFG_LEDC_COM3_GPIO_ID, HTCFG_LEDC_COM3_AFIO_PIN, AFIO_FUN_LEDC);
刷新数码管API:
void DisPlay_Ledc(uint16_t num)
      LEDC_SetData(HTCFG_LEDC_COM_D1,  NumberChar[num/1000]);
      LEDC_SetData(HTCFG_LEDC_COM_D2,  NumberChar[num%1000/100]);
      LEDC_SetData(HTCFG_LEDC_COM_D3,  NumberChar[num%1000%100/10]);
      LEDC_SetData(HTCFG_LEDC_COM_D4,  NumberChar[num%1000%100%10]);
main函数的while
while (1)
        RUN_BLOCK(1000, Runing_LED();) ;//1S反转电平,非阻塞延时
        RUN_BLOCK(100,DisPlay_Ledc(gPotentiometerLevel););//100ms刷新数码管,非阻塞延
实验现象可以看到LED1和LED2以1S闪烁,数码管刷新频率100ms。此时调节可变电阻,可以观察到数码管显示的变化,与仿真一致如图
自此测试完成。
caigang13 发表于 2022-10-2 14:27 来自手机 | 显示全部楼层
板子不错,配置丰富。
chenjun89 发表于 2022-10-4 15:49 来自手机 | 显示全部楼层
可以,不错的板子
Henryko 发表于 2022-10-4 19:46 | 显示全部楼层
配置很丰富啊
xu@xupt 发表于 2022-12-10 13:37 | 显示全部楼层
学习啦,感谢分享
LEDyyds 发表于 2022-12-28 10:36 | 显示全部楼层
过程详细,实现效果较好,大佬厉害
