新人求解,STM32F103的LCD12864串行模式的问题
5455|11
 楼主| yiyanfenghua 发表于 2022-10-4 12:00 | 显示全部楼层 |阅读模式
如何定义,这程序是否有问题,问题出在那?
#include "stm32f10x.h"                  // Device header
#include "Delay.h"
#include "LCD.h"
#define RST_0                GPIO_SetBits(GPIOB,GPIO_Pin_15)
#define RST_1                GPIO_ResetBits(GPIOB,GPIO_Pin_15)
#define PSB_0                GPIO_SetBits(GPIOB,GPIO_Pin_14)
#define PSB_1                GPIO_ResetBits(GPIOB,GPIO_Pin_14)
#define CS_0                GPIO_SetBits(GPIOB,GPIO_Pin_13)
#define CS_1                GPIO_ResetBits(GPIOB,GPIO_Pin_13)
#define SID_0                GPIO_SetBits(GPIOB,GPIO_Pin_12)
#define SID_1                GPIO_ResetBits(GPIOB,GPIO_Pin_12)
#define SCLK_0                GPIO_SetBits(GPIOB,GPIO_Pin_11)
#define SCLK_1                GPIO_ResetBits(GPIOB,GPIO_Pin_11)
#define WRITE_CMD        0xF8//写命令
#define WRITE_DAT        0xFA//写数据
void lcd12864_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_15|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_12|GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        SID_1;
        SCLK_1;
void send_dat(u8 dat)
        u8 i;
        for(i = 0;i < 8;i++)
        if((dat& 0x80)==0x80)
                    SID_1;
                if((dat& 0x80)==0x00)
                        SID_0;
                SCLK_0;
                Delay_ms(50);
                SCLK_1;
                dat<<=1;
*  @brief      LCD写指令
*  @param  Cmd   要写入的指令
void send_cmd(u8 Cmd )
     Delay_ms(1);
     send_dat(WRITE_CMD);
     send_dat(Cmd&0xf0);
     send_dat((Cmd&0x0f)<<4);
*  @brief      LCD写数据
*  @param  Dat   要写入的数据
void write_char(u8 Dat )
         Delay_ms(1);
     send_dat(WRITE_DAT);
     send_dat(Dat&0xf0);
     send_dat((Dat&0x0f)<<4);
*  @brief      LCD初始化
*  @param  None
void Lcd_Init(void)
        RST_0;
        Delay_ms(50);
        RST_1;
        Delay_ms(50);
        CS_1;
    Delay_ms(50);
        send_cmd(0x30);
    Delay_ms(1);
    send_cmd(0x0c);
    Delay_ms(1);
    send_cmd(0x01);
    Delay_ms(30);
        send_cmd(0x02);
    Delay_ms(30);
        send_cmd(0x80);
        PSB_0;
void lcd_addr(uint8_t y_add,uint8_t x_add)
        switch(y_add)
                case 1:
                send_cmd(0x80|x_add);break;
                case 2:
                send_cmd(0x90|x_add);break;
                case 3:
                send_cmd(0x88|x_add);break;
                case 4:
                send_cmd(0x98|x_add);break;
        default:break;
*  @brief      显示字符或汉字
*  @param  x: row(0~3)
*  @param  y: line(0~7)
*  @param         str: 要显示的字符或汉字
void LCD_Display_Words(uint8_t y_add,uint8_t x_add , char *str)
        uint8_t i;
        lcd_addr(y_add,x_add);
        for(i=0;str!='\0';i++)
                write_char(str);
*  @brief      清屏函数
*  @param  None
void LCD_Clear(void)
        send_cmd(0x01);
        Delay_ms(2);
LcwSwust 发表于 2022-10-4 12:41 | 显示全部楼层
这是在问问题还是在出题?
@yiyanfenghua :这哪能看出来问题,谁闲得没事。 这得靠你自己动手去试,编译、烧写到单片机里运行才能看到效果。 “程序是否有问题”得问你自己,遇到了具体的问题才好拿出来问。  发表于 2022-10-4 14:49
问,才疏学浅,不够能力  发表于 2022-10-4 14:42
 楼主| yiyanfenghua 发表于 2022-10-4 15:00 | 显示全部楼层
这是在问问题还是在出题?
编译过了,烧进单片机没有效果,万般无奈才来这问大家,可能发帖的词语用的不太准确,对不起了。
                   tyw  注
高低电平定义没错? 延时时间正确?  发表于 2022-10-9 09:26
LcwSwust 发表于 2022-10-4 15:41 | 显示全部楼层
编译过了,烧进单片机没有效果,万般无奈才来这问大家,可能发帖的词语用的不太准确,对不起了。 ...
代码是LCD12864的卖家给的吗?是开发板配套的显示屏吗?有示波器吗?是否可以看看相关引脚波形?
这些代码不够啊,main都没看到,确定程序写对了?
LCD屏有多种型号,并非随便找个代码都能用,特别是初始化。
 楼主| yiyanfenghua 发表于 2022-10-4 16:05 | 显示全部楼层
这些代码 ...
代码是我移植的,我自己在找找,看那出现的问题。
guixi12 发表于 2022-10-4 19:12 | 显示全部楼层
咔咔咔咔咔咔扩扩
jekey 发表于 2022-10-5 12:32 | 显示全部楼层
似乎你对set和reset的输出都搞反了。
GPIO_SetBits,输出高电平。
GlenX 发表于 2022-10-8 19:58 | 显示全部楼层
你的问题一定是LCD12864的应用问题,我做过很多失败的例子,各种通讯方式,最终都失败了,原因是这些LCD的所谓的串口,都是特定方式的特定字节(包括长度),一般直接USART、IIC、SPI基本都不能直接满足编程,只能用所谓的IO仿真的通讯方式,才能实现。不甘心失败,但这是事实,也许国内的LCD都是以前的老版,接口有待改善!
elec921 发表于 2022-10-8 21:43 | 显示全部楼层
