OKI M80C49 用什么编程器读程序
2098|1
 楼主| keen123456 发表于 2012-4-12 23:02 | 显示全部楼层 |阅读模式
手上有几片M80C49的单片机想看里面的资料  望赐教 谢谢
 楼主| keen123456 发表于 2012-4-15 14:45 | 显示全部楼层
放个代码出来请砖家指点下
#include<stdio.h>
#include<sys/io.h>
#include<unistd.h>
#define BASE 0x378
#define wr(data) (data & 0xcf)
#define rd(data) (data | 0x20)
#define b1off(data) (data & 0xfe)
#define b1on(data) (data | 0x01)
unsigned char read_8049(int addr)
   int data, j, a, b, max;
   unsigned char tmp, code;
   unsigned char buff[40];
   /* we read a byte 40 times. why? because there are errors. the error
      rate is as high as 15% when I tested.  Inserting delays can lower
      the error rate, but won't eliminate it.  I removed artificial
      delays after implementing "the redundant read and vote" thing.
   for (j=0; j<40; j++)
        tmp = wr(inb(BASE+2));   // Write
        tmp = b1off(tmp);         // RESET off
        outb(tmp, BASE+2);
        outb((unsigned char)addr, BASE);  // ADDR
        // blink reset
        outb(b1on(inb(BASE+2)), BASE+2);
        outb(b1off(inb(BASE+2)), BASE+2);
        tmp = rd(inb(BASE+2));   // Read
        outb(tmp, BASE+2);
        buff[j] = inb(BASE+4);
   /* find the most frequent one among 40 reads */
   max=0;
        tmp = buff[j];
        a = 0;
        for (b=j; b<40; b++)
           if(buff[b]==tmp) a++;
        if(a > max)
           code = tmp;
           max = a;
   return code;
int main()
        int i;
        /* initialize */
        if (iopl(3)) return 1;
        for(i=0; i <= 0xff; i++)
                printf("%c", read_8049(i));
