[其他ST产品]
STR911FA42X6进不去中断
378|11
dingy|  楼主 | 2022-10-20 20:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在官网的程序上改的,不知道为何进不去中断?串口和CAN中断都进不去,怀疑时钟的问题?
/* Includes ------------------------------------------------------------------*/
#include "91x_lib.h"
#include "91x_fmi.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define TxBufferSize   (countof(TxBuffer) - 1)
#define RxBufferSize   0xFF
/* Private macro -------------------------------------------------------------*/
#define countof(a)   (sizeof(a) / sizeof(*(a)))
/* Private variables ---------------------------------------------------------*/
  UART_InitTypeDef UART_InitStructure;
  u8 TxBuffer[] = "UART Example1: UART - Hyperterminal communication using hardware flow control\n\r";
u8 RxBuffer[RxBufferSize];
  u8 NbrOfDataToTransfer = TxBufferSize;
  u8 TxCounter = 0;
  u8 RxCounter = 0;
   u8 data =0;
/* Private function prototypes -----------------------------------------------*/
  void SCU_Configuration(void);
  void GPIO_Configuration(void);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program
* Input          : None
* Output         : None
* Return         : None
/*static void Delay(u32 nCount)
  u32 j = 0;
  for(j = nCount; j != 0; j--);
int main()
  #ifdef DEBUG
    debug();
  #endif
  /* Configure the system clocks */
  SCU_Configuration();
  /* Configure the GPIO ports */
  GPIO_Configuration();
  /*  configuration -------------------------------------------------------*/
  /* UART2 configured as follow:
        - Word Length = 7 Bits
        - Two Stop Bit
        - No parity
        - BaudRate = 115200 baud
        - Hardware flow control enabled (RTS and CTS signals)
        - Receive and transmit enabled
        - Receive and transmit FIFOs are enabled
        - Transmit and Receive FIFOs levels have 8 bytes depth
  UART_InitStructure.UART_WordLength = UART_WordLength_8D;
  UART_InitStructure.UART_StopBits = UART_StopBits_1;
  UART_InitStructure.UART_Parity = UART_Parity_No ;
  UART_InitStructure.UART_BaudRate = 9600;
// UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None;
  UART_InitStructure.UART_Mode = UART_Mode_Tx_Rx;
  UART_InitStructure.UART_FIFO = UART_FIFO_Disable ;
// UART_InitStructure.UART_TxFIFOLevel = UART_FIFOLevel_1_2; /* FIFO size 16 bytes, FIFO level 8 bytes */
// UART_InitStructure.UART_RxFIFOLevel = UART_FIFOLevel_1_2; /* FIFO size 16 bytes, FIFO level 8 bytes */
  UART_DeInit(UART2);
  UART_Init(UART2, &UART_InitStructure);
// GPIO_WriteBit(GPIO4, GPIO_Pin_5, Bit_RESET);
  /* Enable the UART Receive interrupt*/
UART_ITConfig(UART2, UART_IT_Receive, ENABLE);
//     UART2->IMSC |= 0x0010;
  /* Enable VIC clock */
//SCU_AHBPeriphClockConfig(__VIC, ENABLE);
  /*configure UART2 interrupt in VIC*/
VIC_DeInit();
VIC_InitDefaultVectors(); /* initialize VICs default vector registers*/
VIC_Config(UART2_ITLine, VIC_IRQ, 0);
/* Enable the UART2 */
UART_Cmd(UART2, ENABLE);
//     VIC1->VAiR[2]=(u32)UART2_IRQHandler;
//      VIC1->INTSR &= ~4;
//      VIC1->VCiR[2] |=0x20;
// VIC1->VCiR[2] &=  0xFFFFFFE0;
//    VIC1->VCiR[2] |=0x02;
//      UART2->CR |= 0x0001;
//       VIC1->INTER |= 4;
/*enable UART2 interrupt for data reception*/
VIC_ITCmd(UART2_ITLine,ENABLE);
while (1)
data = UART_ReceiveData(UART2);
if(data==0xaa)
GPIO_WriteBit(GPIO4, GPIO_Pin_5, Bit_SET);
UART_SendData(UART2,data);
while(UART_GetFlagStatus(UART2, UART_FLAG_Busy) == SET);
   SCU_MCLKSourceConfig(SCU_MCLK_OSC);   /* Default configuration */
  /*wait state insertion :This function should be executed from SRAM when*/
  /*booting from bank1 to avoid  Read-While-Write from the Same Bank.*/
  FMI_Config(FMI_READ_WAIT_STATE_2, FMI_WRITE_WAIT_STATE_0, FMI_PWD_ENABLE,\
                 FMI_LVD_ENABLE, FMI_FREQ_HIGH);/*Insert 2 Wait States for read*/
  SCU_PLLFactorsConfig(192, 8, 2); /* PLL factors Configuration based on*/
                                        /* a OSC/Crystal value = 25Mhz*/
  SCU_PLLCmd(ENABLE);  /* PLL Enable and wait for Locking*/
      SCU_RCLKDivisorConfig(SCU_RCLK_Div1); /* RCLK @Osc/crystal Frequency*/
      SCU_HCLKDivisorConfig(SCU_HCLK_Div1); /* AHB @Osc/crystal Frequency*/
      SCU_FMICLKDivisorConfig(SCU_FMICLK_Div1);/* FMI @Osc/crystal Frequency*/
      SCU_PCLKDivisorConfig(SCU_PCLK_Div2); /* APB @Osc/crystal Frequency*/
      SCU_MCLKSourceConfig(SCU_MCLK_OSC);  /* MCLK @Osc/crystal Frequency*/
  /* Enable UART2 Clock */
  SCU_APBPeriphClockConfig(__UART2, ENABLE);
  /* Enable GPIO2 Clock */
  SCU_APBPeriphClockConfig(__GPIO4, ENABLE);
  /* Enable GPIO5 Clock */
  SCU_APBPeriphClockConfig(__GPIO5, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
  /*Configure UART0_CTS P2.0*/
  //GPIO_DeInit(GPIO2);
  /*After DeInit function P2.0 = UART0_CTS (defaut configuration)*/
  GPIO_DeInit(GPIO5);
  /*Gonfigure UART0_Rx pin GPIO5.2*/
  GPIO_InitStructure.GPIO_Direction = GPIO_PinInput;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ;
GPIO_InitStructure.GPIO_IPInputConnected = GPIO_IPInputConnected_Enable;
  GPIO_InitStructure.GPIO_Alternate = GPIO_InputAlt1  ;
  GPIO_Init (GPIO5, &GPIO_InitStructure);
//  GPIO_DeInit(GPIO3);
  /*Gonfigure UART0_Tx pin GPIO5.1*/
  GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt3  ;
GPIO_DeInit(GPIO4);
  /*Gonfigure UART0_RTS pin GPIO4.5*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
//GPIO_InitStructure.GPIO_IPConnected = GPIO_IPConnected_Enable;
  GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt1  ;
  GPIO_Init (GPIO4, &GPIO_InitStructure);
stly| | 2022-10-20 20:24 | 只看该作者
是否时钟的问题?
dingy|  楼主 | 2022-10-20 20:28 | 只看该作者
为何中断都进不去。串口查询方式可以
renyaq| | 2022-10-20 20:29 | 只看该作者
初始化能通过的话应该不是时钟的问题呀
stly| | 2022-10-20 20:32 | 只看该作者
用的什么时钟?
renyaq| | 2022-10-20 20:34 | 只看该作者
开总中断了没有呀
dingy|  楼主 | 2022-10-20 20:37 | 只看该作者
问题解决了。换了个版本的启动文件,中断就OK 了。谢谢各位。
dingy|  楼主 | 2022-10-20 20:40 | 只看该作者
开了。不是程序的问题
dingy|  楼主 | 2022-10-20 20:43 | 只看该作者
用的OSC
zwll| | 2022-10-20 20:45 | 只看该作者
那晶振起振了吗
dingy|  楼主 | 2022-10-20 20:48 | 只看该作者
谢谢各位。已经解决,因为启动文件有点问题。换了就好了
SantaBunny| | 2023-2-21 22:20 | 只看该作者
切记打开复用时钟
