[N32G45x] N32G45x 窗口看门狗(WWDG)使用
958|1
 楼主| Afanx 发表于 2022-10-31 14:12 | 显示全部楼层 |阅读模式
窗口看门狗(WWDG)
时钟源:APB1时钟/4096
功能:7位递减计数器,具有上下限(0x7F~0x40),当计数器小于0x40时产生复位,另外只能在计数器小于设定的窗口值才能对计数器重装载。 WWDG_Reload.jpg
计数时间:PCLK1=36MHz
预分配 计数频率(Hz) 步进时间(ms) 最大计数时间(ms)
2^0 = 1 8.789k 0.113 7.28
2^1 = 2 4.394k 0.227 14.56
2^2 = 4 2.197k 0.445 29.12
2^3 = 8 1.098k 0.910 58.25
软件配置流程:
1. 配置 RCC_APB1PCLKEN.WWDGEN[11]位使能 WWDG 模块的时钟
2. 软件设置 WWDG_CFG.TIMERB[8:7]位来配置 WWDG 的预分频因子
3. 软件配置 WWDG_CTRL.T[6:0]位,设置计数器的起始值。需要将 WWDG_CTRL.T[6]位设置为 1,以防止在启用后立即复位
4. 配置 WWDG_CFG.W[6:0]位配置上边界窗口值
5. 设置 WWDG_CTRL.ACTB[7]位使能 WWDG
6. 软件操作 WWDG_STS.EWINTF[0]位清除唤醒中断标志
7. 配置 WWDG_CFG.EWINT[9]位使能提前唤醒中断
配置代码:
  1. /**
  2. * [url=home.php?mod=space&uid=247401]@brief[/url]  WWDG初始化
  3. */
  4. void WWDG_Initial(void)
  5. {
  6.     /* Enable WWDG clock */
  7.     RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_WWDG, ENABLE);
  8.     /* WWDG clock counter = (PCLK1(36MHz)/4096)/8 = 1099 Hz (~910 us)  */
  9.     WWDG_SetPrescalerDiv(WWDG_PRESCALER_DIV8);
  10.     /* Set Window value to 80; WWDG counter should be refreshed only when the counter
  11.       is below 80 (and greater than 64) otherwise a reset will be generated */
  12.     WWDG_SetWValue(80);
  13.     /* Enable WWDG and set counter value to 127, WWDG timeout = ~910 us * 64 = 58.25 ms
  14.        In this case the refresh window is: ~910 us * (127-80) = 42.77 ms < refresh window < ~910 us * 64 = 58.25ms */
  15.     WWDG_Enable(127);
  16. }
  17. /**
  18. * [url=home.php?mod=space&uid=247401]@brief[/url]  WWDG测试
  19. */
  20. void WWDG_Task(void)
  21. {
  22.     /* Check if the system has resumed from WWDG reset */
  23.     if (RCC_GetFlagStatus(RCC_FLAG_WWDGRST) != RESET) {
  24.         /* WWDGRST flag set */
  25.         printf("\r\n reset by WWDG \r\n");
  26.         /* Clear reset flags */
  27.         RCC_ClrFlag();
  28.     }
  29.     /* Enable WWDG and set counter value to 127, WWDG timeout = ~910 us * 64 = 58.25 ms
  30.        In this case the refresh window is: ~910 us * (127-80) = 42.77 ms < refresh window < ~910 us * 64 = 58.25ms */
  31.     while (1) {
  32.         /* Delay */
  33.         DelayMs(50);
  34.         /* Update WWDG counter */
  35.         WWDG_SetCnt(127);
  36.         /* Toggle LED */
  37.         GPIO_ToggleBit(GPIOA, GPIO_PIN_8);
  38.     }
  39. }
小黄鸭 发表于 2022-10-31 16:18 | 显示全部楼层
高于窗口上限喂狗也会发生复位吗
