[PIC®/AVR®/dsPIC®产品] MCC,情况就是这么个情况,事情就是这么个事情
2410|31
zhuomuniao110 发表于 2022-11-17 10:13 | 显示全部楼层
宝贵的经验,终于知道我的为何启动不了啦。我多试试看。
lcczg 发表于 2022-11-17 14:11 | 显示全部楼层
gaoyang9992006 发表于 2022-11-16 14:50
还没有搞好呢,点那个图配置管脚,点了没反应。重启了一下,又加载了半天,可以了。不知道啊,我这网特别 ...
我这里试了下整个过程一分多钟吧。
14:02:51.971    INFO: Fetching list of available libraries.
14:02:53.110    INFO: Download Complete: C:\Users\a41438\.mcc\mcc_libraries.xml
14:02:54.088    INFO: Start MCC
14:02:54.110    INFO: Core v5.4.13 loaded.
14:03:18.189    INFO: Loaded configuration from file C:\temp\avr64dd32.X\avr64dd32.mc3
14:03:56.503    INFO: *****************************************************
14:03:56.503    INFO:  Generation Results
14:03:56.507    INFO: main.c                                            Success.
14:03:56.507    INFO: mcc_generated_files\system\ccp.h                  Success.
14:03:56.507    INFO: mcc_generated_files\system\clock.h                Success.
14:03:56.508    INFO: mcc_generated_files\system\interrupt.h            Success.
14:03:56.508    INFO: mcc_generated_files\system\pins.h                 Success. Auto-merged.
14:03:56.508    INFO: mcc_generated_files\system\port.h                 Success.
14:03:56.508    INFO: mcc_generated_files\system\protected_io.h         Success.
14:03:56.508    INFO: mcc_generated_files\system\src\clock.c            Success.
14:03:56.508    INFO: mcc_generated_files\system\src\config_bits.c      Success.
14:03:56.508    INFO: mcc_generated_files\system\src\interrupt.c        Success.
14:03:56.509    INFO: mcc_generated_files\system\src\pins.c             Success. Auto-merged.
14:03:56.509    INFO: mcc_generated_files\system\src\protected_io.S     Success.
14:03:56.510    INFO: mcc_generated_files\system\src\system.c           Success.
14:03:56.510    INFO: mcc_generated_files\system\system.h               Success.
14:03:56.510    INFO: mcc_generated_files\system\utils\assembler.h      Success.
14:03:56.510    INFO: mcc_generated_files\system\utils\assembler\gas.h  Success.
14:03:56.510    INFO: mcc_generated_files\system\utils\assembler\iar.h  Success.
14:03:56.510    INFO: mcc_generated_files\system\utils\atomic.h         Success.
14:03:56.510    INFO: mcc_generated_files\system\utils\compiler.h       Success.
14:03:56.511    INFO: mcc_generated_files\system\utils\interrupt_avr8.h Success.
14:03:56.511    INFO: mcc_generated_files\system\utils\utils.h          Success.
14:03:56.511    INFO: mcc_generated_files\system\utils\utils_assert.h   Success.
14:03:56.561    INFO: *****************************************************
14:03:56.562    INFO:  Generation complete (total time: 464 milliseconds)
14:03:56.562    INFO: *****************************************************
14:03:56.562    INFO: Generation complete.
MPLAB X IDE 6.05的release note (file:///C:/Program%20Files/Microchip/MPLABX/v6.05/docs/Readme%20for%20MPLAB%20X%20IDE.htm) 推荐系统用Windows 10 Professional。不知是否有关。如果有WIN 10的系统,你可以在同样的网络环境下试试。有其他电脑的话,也可以比较一下异同,看看结果,谢谢。
 楼主| gaoyang9992006 发表于 2022-11-17 15:09 | 显示全部楼层
我这里试了下整个过程一分多钟吧。
14:02 ...
只要成功一次,这个文件夹内容就变多了,会从服务器下载回来很多必须的文件,之后就可以正常使用了。
大概500M的内容。在这个文件夹,刚安装时候没多大。  发表于 2022-11-17 15:10
wutaosamuel 发表于 2022-11-17 16:38 | 显示全部楼层
下载完, 把网断了, mcc启动会更快
 楼主| gaoyang9992006 发表于 2022-11-17 19:41 | 显示全部楼层
下载完, 把网断了, mcc启动会更快
en ,是的,每次启动它会再联网检查一遍才启动。
mxkw0514 发表于 2022-11-22 11:26 | 显示全部楼层
我们JAVA开发的软件普遍慢和卡呢?
mxkw0514 发表于 2022-11-22 11:32 | 显示全部楼层
为什么AVR单片机只能用MCC melody呢?
 楼主| gaoyang9992006 发表于 2022-11-22 16:46 | 显示全部楼层
这是针对AVR的版本,毕竟AVR和PIC架构不同啊。
 楼主| gaoyang9992006 发表于 2022-11-22 16:47 | 显示全部楼层
我们JAVA开发的软件普遍慢和卡呢?
是的,反正我讨厌JAVA开发的软件,通常不是很好用,特别是桌面软件。
