[N32G45x] 官方串口打印功能验证没成功
956|3
 楼主| zhouchen605768 发表于 2022-11-20 13:12 | 显示全部楼层 |阅读模式
大家有没有验证基于官方的串口打印的例子,基于开发板N32G45XRL-STB开发板.验证失败的,下面是我验证的代码添加:
void RCC_Configuration(void)
  RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA|RCC_APB2_PERIPH_AFIO,ENABLE); //enable GPIOA  clk
  RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_USART1,ENABLE);                     //enable usart1 clk
#define USARTx_GPIO    GPIOA
#define USART_Tx_Pin   GPIO_PIN_9
#define USART_Rx_Pin   GPIO_PIN_10
void GPIO_Configuration(void)
          GPIO_InitType GPIO_InitStructure;
    /* Configure USARTx Tx as alternate function push-pull */
    GPIO_InitStructure.Pin        = USART_Tx_Pin;
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;       //这个地方换过了几种 GPIO_Mode_Out_OD ,GPIO_Mode_AF_OD,GPIO_Mode_AF_PP
    GPIO_InitPeripheral(USARTx_GPIO, &GPIO_InitStructure);
    /* Configure USARTx Rx as input floating */
    GPIO_InitStructure.Pin       = USART_Rx_Pin;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
USART_InitType USART_InitStructure;
void USART_Printf_Configuration(void)
    /* USARTy and USARTz configuration ------------------------------------------------------*/
    USART_InitStructure.BaudRate            = 115200;
    USART_InitStructure.WordLength          = USART_WL_8B;
    USART_InitStructure.StopBits            = USART_STPB_1;
    USART_InitStructure.Parity              = USART_PE_NO;
    USART_InitStructure.HardwareFlowControl = USART_HFCTRL_NONE;
    USART_InitStructure.Mode                = USART_MODE_RX | USART_MODE_TX;
    /* Configure USARTx */
    USART_Init(USART1, &USART_InitStructure);
    /* Enable the USARTx */
    USART_Enable(USART1, ENABLE);
主函数处理:
int main(void)
        RCC_Configuration();
        GPIO_Configuration();
        USART_Printf_Configuration();
                        printf("N32G45RE printf test.\r\n");
        while(1)
                Delay(0x28ffff);
测试结果无任何的打印数据,有谁知道是什么原因.
 楼主| zhouchen605768 发表于 2022-11-20 23:08 | 显示全部楼层
现在验证ok了,
sy12138 发表于 2022-11-21 13:59 | 显示全部楼层
例程是没有问题的,需要看一下开发板跳线对不对
GGG3 发表于 2022-11-22 09:45 | 显示全部楼层
官方例程,尤其是这么基础的,一般是不会出错的
