 由于N32 MCU PA15引脚比较特殊,上电默认是作为JTAG JTDI 的,如下截图所示:
 如果要将PA15用作其他用途可通过设置 AFIO_RMP_CFG. SW_JTAG_CFG[2:0]位,可以改变上述重映像配置:
 | SW_JTAG_ CFG[2:0] |  |  |  |  |  |  |  |  |  |  | 完全SWD_JTAG(JTAG-DP + SW-DP) (复位状态) |  |  |  |  |  |  |  | 完全SWD_JTAG(JTAG-DP + SW-DP) 但没有NJTRST |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |  |
这里举个例子把PA15用作PWM输出引脚,用定时器TIM8产生PWM,程序配置如下: int main(void){
 /* System Clocks Configuration */
 RCC_Configuration();
 /* GPIO Configuration */
 GPIO_Configuration();
 TIM_Intial(TIM8);
 while (1)
 void RCC_Configuration(void){
 /* TIM8 clock enable */
 RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_TIM8, ENABLE);
 RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_AFIO,ENABLE);
 /* GPIOA,GPIOC,GPIOD  clock enable */
 RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA | RCC_APB2_PERIPH_GPIOC | RCC_APB2_PERIPH_GPIOD , ENABLE);
 void GPIO_Configuration(void)
 GPIO_InitType GPIO_InitStructure;
 GPIO_ConfigPinRemap(GPIO_RMP_SW_JTAG_SW_ENABLE,ENABLE);
 GPIO_ConfigPinRemap(GPIO_RMP1_TIM8,ENABLE);
 /* GPIOA Configuration:TIM8 Channel1, 2, 3 and 4 as alternate function push-pull */
 GPIO_InitStructure.Pin        = GPIO_PIN_15 ;
 GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
 GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
 GPIO_InitStructure.Pin = GPIO_PIN_6 | GPIO_PIN_7 | GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_12  ;
 GPIO_InitPeripheral(GPIOC, &GPIO_InitStructure);
 GPIO_InitStructure.Pin = GPIO_PIN_2 ;
 GPIO_InitPeripheral(GPIOD, &GPIO_InitStructure);
 void TIM_Intial(TIM_Module* TIMx)
 /* TIMx Configuration ---------------------------------------------------
 Generate 7 PWM signals with 4 different duty cycles:
 TIM1CLK = SystemCoreClock, Prescaler = 0, TIM1 counter clock = SystemCoreClock
 SystemCoreClock is set to 72 MHz for Low-density, Medium-density, High-density
 and Connectivity line devices and to 24 MHz for Low-Density Value line and
 Medium-Density Value line devices
 The objective is to generate 7 PWM signal at 17.57 KHz:
 - TIMx_Period = (SystemCoreClock / 17570) - 1
 The channel 1 and channel 1N duty cycle is set to 50%
 The channel 2 and channel 2N duty cycle is set to 37.5%
 The channel 3 and channel 3N duty cycle is set to 25%
 The channel 4 duty cycle is set to 12.5%
 The Timer pulse is calculated as follows:
 - ChannelxPulse = DutyCycle * (TIM1_Period - 1) / 100
 /* Compute the value to be set in AR regiter to generate signal frequency at 17.57 Khz */
 TimerPeriod = 50; //(SystemCoreClock / 17570 ) - 1;
 /* Compute CCDAT1 value to generate a duty cycle at 50% for channel 1 and 1N */
 Channel1Pulse = (uint16_t)(((uint32_t)5 * (TimerPeriod - 1)) / 10);
 /* Compute CCDAT2 value to generate a duty cycle at 37.5%  for channel 2 and 2N */
 Channel2Pulse = (uint16_t)(((uint32_t)375 * (TimerPeriod - 1)) / 1000);
 /* Compute CCDAT3 value to generate a duty cycle at 25%  for channel 3 and 3N */
 Channel3Pulse = (uint16_t)(((uint32_t)25 * (TimerPeriod - 1)) / 100);
 /* Compute CCDAT4 value to generate a duty cycle at 12.5%  for channel 4 */
 Channel4Pulse = (uint16_t)(((uint32_t)125 * (TimerPeriod - 1)) / 1000);
 /* Time Base configuration */
 TIM_TimeBaseStructure.Prescaler = 0;
 TIM_TimeBaseStructure.CntMode   = TIM_CNT_MODE_UP;
 TIM_TimeBaseStructure.Period    = TimerPeriod;
 TIM_TimeBaseStructure.ClkDiv    = 0;
 TIM_TimeBaseStructure.RepetCnt  = 0;
 TIM_InitTimeBase(TIMx, &TIM_TimeBaseStructure);
 /* Channel 1, 2,3 and 4 Configuration in PWM mode */
 TIM_OCInitStructure.OcMode       = TIM_OCMODE_PWM2;
 TIM_OCInitStructure.OutputState  = TIM_OUTPUT_STATE_ENABLE;
 TIM_OCInitStructure.OutputNState = TIM_OUTPUT_NSTATE_ENABLE;
 TIM_OCInitStructure.Pulse        = Channel1Pulse;
 TIM_OCInitStructure.OcPolarity   = TIM_OC_POLARITY_HIGH;
 TIM_OCInitStructure.OcNPolarity  = TIM_OCN_POLARITY_HIGH;
 TIM_OCInitStructure.OcIdleState  = TIM_OC_IDLE_STATE_SET;
 TIM_OCInitStructure.OcNIdleState = TIM_OC_IDLE_STATE_RESET;
 TIM_InitOc1(TIMx, &TIM_OCInitStructure);
 TIM_OCInitStructure.Pulse = Channel3Pulse;
 TIM_InitOc3(TIMx, &TIM_OCInitStructure);
 TIM_OCInitStructure.Pulse = Channel4Pulse;
 TIM_InitOc4(TIMx, &TIM_OCInitStructure);
 // TIM_OCInitStructure.OutputNState = TIM_OUTPUT_NSTATE_DISABLE;
 TIM_OCInitStructure.Pulse = Channel2Pulse;
 TIM_InitOc2(TIMx, &TIM_OCInitStructure);
 /* TIM8 counter enable */
 TIM_Enable(TIMx, ENABLE);
 /* TIM8 Main Output Enable */
 TIM_EnableCtrlPwmOutputs(TIMx, ENABLE);
